So guys i have a gtx 1060 3gb,i3 6098p 1 hdd 1 8gbDDR4 ram and i am using a Corsair vs550 for PSU.I want to upgrade this PSU cuz from what i've heard its not trustworthy and also its not recommended for gaming.And i found this psu :Corsair RMX 550 80 plus gold.The problem is that in the future i will probably buy a 2nd ram and a new cpu+mobo(i5 8500+H3 series when they come out)and i dont know if 550 watts are going to be enough or not.
So what do you guys think.Are 550 watts going to be enough to handle my system or i should get the RMX 650(which btw is more expensive Thx 550 costs 89$ and the 650 104$)
Thank you and sorry for bad english i am from Greece
https://linustechtips.com/topic/896887-550w-enough-for-my-system/
use partpicker it should tell you on it or http://www.coolermaster.com/power-supply-calculator/ that will tell you.
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
5 minutes ago, grimreeper132 said:
No
We already answered your question in another thread
Just get CX450/CX450M, maybe PURE POWER 10
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
2 minutes ago, STRMfrmXMN said:
No
I thought those calculators were meant to be alright
They overestimate like f***
According to the CM one like a year ago a R7 370 + I5 4460 will take 500W minimum, recommended 584W
Full Specs
Helios EVO (Main):
Delta - Laptop
The Cooler Master one wildly overestimates plus has monetary incentive to. Don't bother using it.
oh right fair enough you got a good one you can recommend. Also I liked it because at a certain power it suggested an arc reactor to power it
So a 550 watt will do its job fine?(with an i5 8500 and a 2nd ram and current gpu?)
13 minutes ago, NickWolf said:
What about pcpartpicker.Is it more accurate?
Yes, but 339W is still more than what a 1060 would use by about 100W.
A CX450M would be fine for your system now, a CX550M would be fine for a 1080Ti.
