HELP Hyper 212 EVO
Go to solution Solved by CM Norumu,
Hi! I'm Kevin with Cooler Master USA  :)
The Hyper 212 Plus and Hyper 212 EVO will be able to twist a little bit when it's completely mounted if you are applying the force to twist it. If it's moving at all on its own, though, that's not right. In that case, I'd double check to make sure everything is tightened and the right mounting parts were used.
Hyper 212 Intel mounting guide
Hyper 212 AMD mounting guide
If it turns out something is broken or missing, come find me or any of our other support members on Live Chat or in the ticket system through here. You can also hit up our Part Request system if you need just a screw or bracket or something like that covered under warranty. :D (Note: This is for North America customers. For other countries, your best point of contact will be the ticket system. )
Ok so I have the evo installed and screwed on but it still likes to move around that cant be right? Can someone tell me if thats normal or not?
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/89034-help-hyper-212-evo/
How much is it moving, is it only moving when you twist it, or does it move on its own? Regardless it sounds like you probably need to tighten it down or reinstall it.
Intel 3570k @ 4.4 GHz |Asus Sabertooth Z77 |EVGA GTX 660 Ti FTW |Kingston HyperX Beast 16 Gb DDR3 1866 (2x8Gb)
|Samsung 840 250 GB |Western Digital Green 2TB 2x |Cooler Master 850w 80+ Gold |Custom Water Cooling Loop |Noctua NF-F12 4x
|Noctua NF-A14 3x |Corsair Carbide 500R (White) |Corsair K95 |Razer Mamba |Razer Megalodon |Samsung SyncMaster T220 2x Computer Bucket List   Greatest Thread Ever   WAN Show Drinking Game  GPU Buyers Guide
https://linustechtips.com/topic/89034-help-hyper-212-evo/#findComment-1205018
Yea I followed the instructions and a youtube guide.
https://linustechtips.com/topic/89034-help-hyper-212-evo/#findComment-1205019
its tightened all the way only moves when you twist it and when twisting it doesnt move that much
https://linustechtips.com/topic/89034-help-hyper-212-evo/#findComment-1205026
Again, how much/how easily is it moving, on its own or when you twist it. Can you screw it down more?
https://linustechtips.com/topic/89034-help-hyper-212-evo/#findComment-1205029
If the temps are fine than you are probably fine, see if you can tighten the bolts more.
https://linustechtips.com/topic/89034-help-hyper-212-evo/#findComment-1205032
only thing I see was the spring on top of the heatsink block isnt down all the way is that doing something?
https://linustechtips.com/topic/89034-help-hyper-212-evo/#findComment-1205035
I left mines like that it only twists when I do it and gets a little better once the thermal paste sets in.
2500k 4.0ghz,GTX 1070 oc,MSI Z77A-GD55,G.SKILL Ripjaws(4 x 2GB)DDR3 1333,OCZ Arc 100 240gb,Samsung Spinpoint F3 1TB,Corsair TX 750w v1,CoolerMaster HAF 912,Hyper 212 EVO
https://linustechtips.com/topic/89034-help-hyper-212-evo/#findComment-1205061
It's normal to be able to be twisted a tiny bit, but it should not rock back and forth at all.
Gaming PC
  • SSUPD Meshlicious White Full Mesh
  • Corsair SF650 Platinum
  • ASrock B550 Phantom Gaming ITX/ax (Won a giveaway from OptimumTech)
  • Ryzen 5 5600X w/ Scythe Big Shuriken 3
  • 2x8gb G.Skill Flare X @3200 CL14
  • PowerColor Gigabyte RX 6750 XT
  • Storage:
    • Samsung 970 Evo NVME
    • Samsung 860 Evo 2.5"
    • MyDigitalSSD BP4 250gb (mSATA inside 2.5" enclosure)
  • W11Pro
  • AOC C24G1 + Dell S2415H
  • Cheap CyerPower keyboard (Wooting 60HE coming later this year)
  • Glorious Model O Matte White
  • LTT Northern Lights DeskPad 1000mm x 500mm
  • FX Audio Dac-X6 + Monoprice Modern Retro + Fifine Studio Condenser Mic
Media Server
  • Rosewill RSV-L4412U 12-bay hotswap
  • Unraid 6.9.2
  • Asrock B450 Steel Legend
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • 9x 2tb IronWolf • 2x 2tb WD Red • 1x 14tb WD Shucked White Label
  • MSI GTX 1050 Ti
https://linustechtips.com/topic/89034-help-hyper-212-evo/#findComment-1205099
Check the brackets and tools and redo it as a proper sequence.
aka, use the right tools and us redo it the right way. redo
To love is to risk not being loved in return. To hope is to risk pain. To try is to risk failure, but risk must be taken because the greatest hazard in life is to risk nothing.
https://linustechtips.com/topic/89034-help-hyper-212-evo/#findComment-1205625
It should twist a little when you you twist it. Bit it shouldn't move on its own at all.
CPU: Intel i7-3770k at 4.8Ghz  CPU Cooling: 320mm UT60  Motherboard: MSI Z77A-GD55  RAM: G.Skill Ripjaws X Series 16GB 2133Mhz (2x8GB)  SSD: Intel 330 Series 120GB  HDD: WD 1TB Caviar Green  GPU: EVGA GTX 780 x2  Sound Card: Creative Recon3D  PSU: Raidmax RX-1000AE 1000W  Case: Arc Midi R2  Monitor: Benq XL2420T at 129Hz  OS: W8 64Bit  Keyboard: Razer Blackwidow 2013 Ultimate  Mouse: Logitech MX518  Mousepad: Steelseries QCK+  Headset: Turtlebeach X12 (Temp.)
https://linustechtips.com/topic/89034-help-hyper-212-evo/#findComment-1213017
Cooler Master USA representing! Looking for help? Head to the CM Fanzone to get in touch with the Customer Support team!
https://linustechtips.com/topic/89034-help-hyper-212-evo/#findComment-1221150
