Dual Monitor Troubleshooting?
Ben Bibedorf
So I recently got a new 4k monitor, however my other monitor is 1440p. This has caused some issues when moving my cursor from one to the other, because they are the same physical size. I could possibly fix this by downscaling the resolution of the 4k monitor, however i would much like to keep it at 4k. Is there any other solution to this? If you can see from the display settings image, it seems to think screen 2 is physically larger than 1, even though they are the same.
No, this view doesn't care about display size, the resolution is just different. How do I you think that should work? Lol.
Like for example stretching a window over both monitors, the window has to be in two different resolution, which is not possible. Therefore the cursor jumps over the edge.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
well that sucks, thanks anyways!
center the monitors horizontally so the middle of each monitors line up
