R5 1600 will bottleneck with gpu`s ?
PSP.
Hello
i have ryzen 5 1600 ( did not oc cpu )
i want buy high video card
montior 1080p 144hz 1ms ( have DAS mode )
i worry about bottleneck ( Ram 16gb . SSD 120gb  1tb hdd )
1080ti or 1080 or 1070ti or 1070 ?
i want best gpu can run esey 144hz
I do not know the key to success, but the key to failure is trying to please everyone
Depends on the game.
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
Just go for the 1080. No reason to worry about a bottleneck today when the card is going to have trouble after two generations.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
1070ti/1080, if you can find one reasonably priced
Desktop benching:
I don't have the 1600 but instead the 1700 with a 1070 running on a 1080p @ 144hz.  It might not be the most ideal setup but I've been happy with it.  Mostly playing COD WW2 right now, getting 150FPS+.  CPU 30-50% across the cores/threads and 1070 running at 98% during game play with VRAM maxed.  This is a newer system for me and haven't really tried any other games to comment on.
Depending on where you are GPU prices and availability are a bit of a mess right now.  I think you'd be happy with any of them really but looking back I would have went with 1070TI.  I got my 1070 at a decent discount over black friday sales and no regrets on the purchase.
Achieving high refresh rates is the CPU role though.... the Ryzen 5 1600 is not ideal solution for 144hz, since you may decrease graphical quality but not gain more fps since your CPU potential will be max out regardless.
With that said the 1070 Ti is as far as I'd go with a Ryzen 5 1600.
Personal Desktop":
Luna, the temporary Desktop:
For games that it actually matters and helps to be hitting 144fps in (CS:GO, Overwatch etc) the 1600 will be fine and won't bottleneck.
PC - CPU Ryzen 5 1600 - GPU Power Color Radeon 5700XT- Motherboard Gigabyte GA-AB350 Gaming - RAM 16GB Corsair Vengeance RGB - Storage 525GB Crucial MX300 SSD + 120GB Kingston SSD   PSU Corsair CX750M - Cooling Stock - Case White NZXT S340
Peripherals - Mouse Logitech G502 Wireless - Keyboard Logitech G915 TKL  Headset Razer Kraken Pro V2's - Displays 2x Acer 24" GF246(1080p, 75hz, Freesync) Steering Wheel & Pedals Logitech G29 & Shifter
Will not bneck even a Titan V at 1440P or higher.
Intel Xeon E5640 4510mhz 1.10v-1.42v (offset) - C states on (◣_◢) 16GB 2x4 1x8 1296mhz CL7 (◣_◢) ASUS P6X58DE (◣_◢) Radeon R9 Fury Sapphire Nitro (◣_◢) 500GB HDD x2 1TB HDD x2 (RAID) Intel 480GB SSD (◣_◢) NZXT S340 (◣_◢) 130hz VS VX2268WM
22 hours ago, Thinkfreely said:
IT will bottleneck the 1080-1080ti. The 1070ti or 1070 not as much, but its more because the core speed is slower compared to Intel, then it is anything else.
yesterday i oc`d my ryzen 5 1600 at 3,7
if i buy 1080ti or 1080 will no bottleneck ?
oc`d at 3.7 will work fine with 1080 or 1080ti ?
Get the 1080ti
Even if it does bottleneck in some games you can upgrade to a better resolution monitor in the future
Sorry been busy, but yes it should be fine, but like Etho said you can also upgrade.
I would rather agree on what we share, than fight on what we don't. - Myself
FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/
