1080ti + R5 1600 = Low GPU Usage
iiNNeX
For some reason in a few games (Battlefield 1, GTA V and a few other AAA titles) my 1080ti is only at 50-65% usage (fluctuating). That would normally indicate a CPU bottleneck, correct?
I play on 2560x1440 on a 165hz monitor. The R5 1600 is overclocked to 3.9ghz and I assumed it would not be an issue. For example Rainbow Six Siege uses 95% GPU and I get 160+ frames at all times, but a large portion of the others don't. My Firestrike and Cinebench scores are better than the average 1600 + 1080ti system so it should be working as expected, meaning it's probably the cpu...
Any input on this?
7800x3d - RTX 4090 FE - 64GB-6000C30 - 2x2TB 990 Pro - 4K 144HZ
PCPP: https://uk.pcpartpicker.com/list/mdRcqR
Any input on this?
Low GPU usage alone isn't indication of a CPU bottleneck. You also need the CPU to have a disproportionately high usage or CPU usage that is capped.
Hmm here are some screenshots.
As above, probably not, especially at 1440P. I would look at drivers and ram usage to start with. Also ensure your ram us running 3000mhz as it will default to 2133mhz on Ryzen
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
Ram is running to 3000 with XMP profile enabled, RAM usage is posted above in screenshots. I have 16gb total so it should be fine.
Drivers are the latest on a fresh Win 10 Pro copy.
It would be game engine bottleneck.
Some games (MMORPGs mostly) will benefit from strong single cores.
For example my GTX 1070 usage was 50%, and CPU (Ryzen 1700) was 30%. Yet I got 30fps in BDO.
Now I'm using i5 8600k at 60% load and GTX 1070 working at 80-90% ... getting smooth 60-75fps in BDO.
Hard to say what's the cause of your problem, but I'm certain that if you put i5 8600k or 8700k in your system, you would have much higher fps. At least those are my experiences with some games.
Overwatch had no problems on R7 1700, delivering me same amount of fps as now on 8600k, so it kinda depends on the game and it's engine.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
try DSR and run BF1 at 4k, see if GPU usage goes up
Ryzen Ram Guide
That would be case if GTA5 and BF1 weren't multi threaded. The usage is around 50% so it isn't a bottleneck - BDO is a heavily single threaded game which actually quite rare now in terms of the newer games
Ryzen Ram Guide
also try again in DX12
Ryzen Ram Guide
I am planning on getting a 8700k system and just transferring my 1080ti over, Ryzen is unfortunately not good enough single thread wise to reach 165frames in most competitive games I play. It's fine on the casuals though.
4 minutes ago, M.Yurizaki said:
Average CPU usage is too low to be considered a bottleneck. It would also be better to post CPU usage from Task Manager in the "Logical Processors" view.
I will split the cpu cores and take another screenie
Will do
No, DX12 is horrendous.
Ryzen-R7-1800X-Test-CPU-Core-Scaling-Bat
Core scaling takes a significant diminishing returns after 6 threads. Meaning his CPU usage will probably be just a tad over 50% given his 12 threads. It's a CPU bottleneck, but i'm seeing 80-92fps (should be good, no?). If you were aiming for 144hz you should've gotten the 8700K and overclocked it.
Yes it is a CPU bottleneck even if the CPU isn't maxing out, Ryzen is not the solution one should ever buy to pair it with a 1080 Ti for 165hz gaming lol... the person above explained it very well just one note though @Majestic the i7 8700 suffices perfectly for the matter, gaming it always is around 4.4ghz~4.5ghz on the latest IPC that is already way faster than Ryzen 5 1600 at 3.9ghz.
He could have gotten the appropriated CPU and still save money.
check the benchmarks down: already set the time:
Personal Desktop":
Luna, the temporary Desktop:
  Reveal hidden contents
This is my temporary PC man, I just put the 1080ti in to see how it will game while waiting to get the i7 kit. Also it has to be the K, 5ghz+ is the only way ;)
Cheers anyway, even at 4K the Ryzen CPU has ridiculously high usage lol
I decided to go back and see what the R5 1600 should be getting in DX11. It's around 110-120 FPS for 1080p, and I did find a 1440p benchmark that showed it at ~90 FPS.
So... there's no hardware bottleneck per se. The game just isn't designed well enough.
To spend money without need at such high resolution you still face GPU bottleneck regardless but I won't argue, just one note, I'm not a man.
Cheers for finding your bottleneck, happy upgrading.
Personal Desktop":
Game ran perfectly on my 6700k and 1080 SLI system that I had before this, so I guess it's just Ryzen in this instance.
True however you can achieve those frames with an i7 and slightly more optimized settings, and apologies didn't know :) What FPS does your non K CPU get on CPU intensive games compared to 5ghz variants ?
Thank you!
The software is the "bottleneck" in the sense of not utilizing all the CPU threads well however due to it the CPU with better threads it manages utilizing will see vantage in performance. The upgrade still makes sense... seems OP had the idea all along regardless.
Personal Desktop":
4 minutes ago, iiNNeX said:
Thank you!
I wish I could help you with numbers but my bad/good luck is that I put the computer together and never got to use it because the second hand super cheap killer deal on G.Skill Trident Z memory end up getting me a kit where one of the sticks was faulty, kinda reason why the super good price heheh... I didn't mind it though, shipping from Brazil to USA for the RMA was still cheaper than buying it new and now I'm receiving a brand new replacement kit... worth it for savings despite the hassle and been waiting  a whole month to actually boot up this system.
At least it's almost here already...
Personal Desktop":
Damn sorry to hear, it's lovely piece of kit that ram, I really want a 3600mhz version of it for my new build but it will have issues fitting under the NH-D15 unless I change one of the fans to a 120mm, but then it will cover the ram sticks so i wont see the lovely RGB :(...Maybe a reason to go custom water cooling again ? lol
I never said it wasn't, I wanted to know if the usage changed by trying it, also I would take that review with a pinch of salt as the review hardware states "DDR3 2133" ...
firstly Ryzen is DDR4,
secondly, everyone knows it performs terribly on slow ram and considering they pushed they res down to 720p to prove CPU efficiency and then crippled the inifinity fabric in the process doesn't provide very accurate testing results - I'm not saying it should be run on 4000mhz ram, but I think 3000mhz is the norm, mine is running 3200mhz and difference at 1080p from 2133 to 3200 was substantial, it would be even greater at 720P and then to top it off they use 4 dims ....
Ryzen Ram Guide
it's a cpu bottleneck, i would not have paired a 1080 or a 1080 ti with ryzen, as it cannot handle 120/144, let alone 165 hz in some games.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
