1 minute ago, ErykYT3 said:
NZXT S340 Elite?
I've got a mate with the S340 Elite and i have a Phanteks P400S TG and we compared the two cases, Phanteks seems to offer better build quality & looks (subjective of course) the Phanteks also has built in ARRGEEBEE and the sound deadening makes a big difference in the P400S, but when it comes down to it the cases are very similar and you cannot go wrong with either, but if you want the absolute best (that i know of) budget case, it appears that the P400S TG is the way to go
System ProjectLuX
AMD Ryzen 5 3600
Sapphire 5700 XT Nitro+
ASUS Prime X370-Pro
G.Skill 2x16GB Trident Z Neo 3600 C16
Arctic Liquid Freezer II 280mm
Phanteks P400S Tempered Glass
Drives:
Boot Drive- Samsung 960 Evo 250GB
Games- Seagate Barracuda Compute 3TB (2016)
Audio:
DAC: Schiit Modius
Headphone Amplifier: Schiit Asgard 3
Speaker Amplifier: Yamaha AS501
Speakers: Dali Zensor 3
Subwoofer: Dali E12-F
Headphones: HifiMan Ananda & Sennheiser HD 558
IEM: Sennheiser Momentum True Wireless
2 minutes ago, Mateyo said:
Ok, so I've done some research and I've come up with some nice, below $100 mid/high end cases, here they are:
Fractal Design Meshify C (HERE)
NZXT s340 Elite (HERE)
SIlverstone RL06 Pro (HERE)
Phanteks P400 (HERE)
Thats the base P400, the extras offered by the P400S TG are worth the small premium: http://www.phanteks.com/Eclipse-P400S-TemperedGlass.html
System ProjectLuX
AMD Ryzen 5 3600
ASUS Prime X370-Pro
Drives:
Audio:
DAC: Schiit Modius
You're right, my bad. The P400Scomes with a way cooler sidepanel and other features
19 hours ago, samladin86 said:
I'm looking to buy a case in the $100 dollar range with tempered glass any suggestion on a good case.
Meshify C, Enthoo Pro M TG, Corsair 460x are the only other good cases not mentioned so far.
11 hours ago, samladin86 said:
While looking at all the case ran into the thermaltake view 31 RGB any thoughts on that one
Doesnt have great airflow. The Core X31 is better because it has a mesh front, however, overall thermaltake cases tend to be lower quality than others mentioned.
