Hello,
On Monday I am going back to the UK and have ordered a new motherboard that will be shipped to there.
I was planning to leave my old mobo in Italy, but that means that I will have to carry RAM and CPU outside of the computer (planning to keep them in their original packaging - for the CPU, just the small plastic part, not the whole box).
As I cannot find any rubbing/isopropyl alcohol here, I have ordered a cleaning product from Arctic which will be shipped with the new mobo. Do you think it is a problem if I leave the thermal paste on the CPU for about a day before cleaning it off?
Sorry for the newbish question but I have never cleaned thermal paste before. Also, do you think I risk to bind the CPU pins by keeping it in its plastic box and packed between clothes, should I keep it with me in my jacket pocket?
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/882249-cleaning-thermal-paste-off-cpu-after-a-while/
no, not a problem exept that its going to end up everywhere the top of the CPU touches. id whipe it of with just some paper first, should get most of it and then you can use the artic stuff once you pick it up
Builds:
2 minutes ago, WereCatf said:
Personally, I just rub the old paste off with a paper towel.
And no solvent?
Unraid Server
I highly doubt it. I took the cooler off my Core i5 750 and just left everything exposed without cleaning off the paste...it was just sitting there for weeks, and I just wiped it off with isopropyl alcohol. I don't think it'll dry out.
