Corsair void pro wireless vs Logitech G533 vs Steelseries Arctis 7
Phantonex
I think the G533 has the better sound quality and its more comfortable than the void and it has noise reduction as well. However, when you compared the G533 to the Artis 7, they both have the same sound quality, but the Artis 7 is every so slightly more comfortable and it has a better build quality. the Artis 7's noise reduction is better than the G533. What really stands out in the Artis 7 is its microphone; it's so much more flexible than the G533. Overall, the Artis 7 is the clear winner of the bunch.
https://www.amazon.com/SteelSeries-Lag-Free-Wireless-Headset-Headphone/dp/B01LYNEIEI/ref=sr_1_1?ie=UTF8&qid=1515219271&sr=8-1&keywords=arctis+7
Its currently only 100 USD on Amazon from its usual 150 USD.
