Basically, I really need help choosing a case for water cooling. I've gone through sooo many choices (NONE THAT HAVE VISIBLE NON REMOVABLE DRIVE CAGES) and the biggest problem is finding one with fron 360 rad support with push pull or only push if I have to and fitting an EKWB standalone 250 reservoir between the (looking from the front) right side of the GPU and the end the PC case. Just PLEASEE HELP. I think most of the reason that I can't find one to fit is because I've never hardline water cooled or even built a PC (don't tell me not to hardline cool for first PC because I'm very confident with building a PC for the first time and have done a LOT of research about hardline so I'm ready) so I don't how much space things usually take up. All help is appreciated :)
Retrowave
Air cooled version of my first PC.
CPU: Intel Core i7-8700K
Cooler: Corsair H150i PRO
Thermal Compound: Thermal Grizzly Kryonaut Thermal Paste
Motherboard: Asus ROG MAXIMUS X HERO (WI-FI AC)
RAM: G.Skill Trident Z RGB 32GB (4 x 8GB) DDR4-3600 Memory
SSD: Samsung 960 Pro 512Gb M.2-2280 Solid State Drive
SSD 2: Samsung 970 EVO Plus 1TB M.2-2280 Solid State Drive
HDD: WD Black 6TB 3.5" 7200RPM Internal Hard Drive
HDD 2: Seagate Barracuda PRO 4TB 3.5" 7200RPM Internal Hard Drive
GPU: EVGA GeForce GTX 1080 Ti FTW3
Case: LIAN LI O11 Dynamic XL
PSU: EVGA SuperNOVA P2 1000W 80+ Platinum Fully-Modular ATX Power Supply
Case Fans: Corsair LL120
Fan Controller: Corsair Commander Pro
Set Up
  • Mouse: Razer Deathadder Elite
  • Keyboard: Razer Blackwidow X Chroma
  • Mousepad: Steelseries QcK Gaming Mousepad
  • Monitor: Asus ROG Swift PG278QR
  • Audio
    • AMP: Sennheiser GSX1000
    • Headphones: Sennheiser 58X
    • Speakers: Bose Companion 2 Series III
  • Oculus Rift + Touch 3 Sensor Roomscale Setup
https://linustechtips.com/topic/880315-case-for-hardline-watercooling/
Define R6 should do that
Builds:
THANKS SO MUCH, I'll check it out. Can you please recommend as manyyy as you think will work so I could find the perfect one? It's alright if you don't :)
Retrowave
Set Up
  • Audio
BeQuiet darkbase 900 is the only one that comes to mind, but im not that good on cases tbn
Builds:
HOLY SHIT efine R6 is FUCking perffffffect, thanks soo much you saved me a lot of anxiety. Dont need more cases :)
Retrowave
Set Up
  • Audio
Yah I absolutely love the R6, it's a great case :)
Builds:
but its preorder?? or is that only for tempered glass version. anyways I will have to wait anyways because ekwb parts need some time.
Retrowave
Set Up
  • Audio
I can buy it right now here in Sweden? Also I personally wouldn't go with EK for my blocks, poor performance(not as in bad, just not the best) and quality control
Builds:
For hardline water I'd go with a Corsair Obsidian 900D
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
I was looking at it but the airflow wasn't too good, its big, and generally I dont really like it. THanks though!
Retrowave
Set Up
  • Audio
okay so what type of case do you want?
زندگی از چراغ
well I want one with good airflow so the rad fans can work well, preferably a 240 rad bottom support, and good space to fit 360 rad and fans and reservoir between gpu and front of case.
Retrowave
Set Up
  • Audio
You could go for the Corsair Obsidian 750D airflow edition, it supports a 240mm in the bottom (once you remove the HDD cage mountings) and it supports a 360mm in the top.
http://www.corsair.com/en-gb/obsidian-series-750d-airflow-edition-full-tower-atx-case
Edited by LinusTechTipsFanFromDarlo
زندگی از چراغ
It's coming out on the 15th, it's actually the case I'll be using ;)
Want to custom loop?  Ask me more if you are curious
thanks but I just love the define r6 :), thanks for all the recommendations though!
Retrowave
Set Up
  • Audio
That's the designed in Sweden advantage I guess, US release is on the 15th of Jan.
Basically lol, only one retailer that has it last time I checked though. But they are the same ones that have literally got motherboards and graphics cards with their branding lol
Builds:
What CPU and GPU(s) and motherboard form factor do you have? That would help us recommend a case that can hold enough radiators and everything else. I would recommend the Define R6 with dual 360 radiators for dual GPU and higher TDP cpu. The new caselabs SMA8-A (if you can afford it) is also a good choice, supporting a top 60mm 480, a front 360, and a bottom slim-medium 560. What sort of radiators do you want/need? - that picks your case. Don't go with the NZXT H700i. The cable management cover thing (to the right of the mobo) will block all reservoirs. A 250 res may be too large for a mid tower. Also look at the lian li PC-V3000 (corsair 900D with tempered glass, RGB and aluminum, pretty much), it supports a top 420, a front 360, and a bottom 480 radiator. I was faced with the same problem a few weeks/months ago to pick what case I wanted, and I settled on the SMA8-A.
Watercooling Pro & Keyboard Enthusiast!
The R6. Do it. Mine will be here tomorrow!
i7 12700k @ 5.1GHz OC (EKWB) / Msi Edge wifi ddr4 / Asus TUF 3080ti (EKWB) / Acer XB327 270HZ, 3x LG 27GL83A-B 144hz, SONY KDL40D3000 Thermaltake P5 / 32gb Corsair Dominator Platinum 3600 / Samsung 980 pro 1tb NVMe ssd, Serbrent 1tb NVMe ssd,Samsung 850 EVO 500GB, Samsung 860 PRO SSD (raid), 2 TB Seagate HDDSeasonic TX 1000w titanium/ EK-FC1080 Ti GTX ASUS Strix RGB GPU Block, EK-Supremacy EVO, EK-CoolStream XE 360 [6x120 Thermaltake Ring fans], EK-CoolStream XE 360 slim [6x120 Thermaltake Ring fans],  EK-DDC 3.2 PWM Elite Edition, EK-RES X3 250 RGBMountain Everest custom with Sorbothane sound dampening / Razer Viper Ultimate, Logitec G502 , Logitec G Pro Wireless / Beardynamic DT1990 PRO with Litz wire full conversion to balanced, custom cable in Litz, Dakoni ear pads going through Topping E30 DAC to Singxer SA-1 amp/Sennhieser HD598, Sennhieser GSP 670, Custom Floor Standing Speakers in 5.1, Panasonic amp. Rode NT-USB on Rode boom.
I know, I never knew I would ever get excited about a PC case, also, where did you get yours because Newegg only allows black preordering but I want blackout
Retrowave
Set Up
  • Audio
I got it, its built. i'm in the UK. Get it. You're welcome
LOL
LOL
pics now bitch, jk but pics pls
Retrowave
Set Up
  • Audio
In Win 909 :) there you can fit a 360 or even 480 and as thick as you wish... and you can add 2 more 240 or 280 rads :D
I own it... best freaking case, but a bit costy :D
gonna check it out but probs not gonna switch
Retrowave
Set Up
  • Audio
