Is high static pressure or cfm better for cpu towers?
brownninja97
So I have a Raijintek Ereboss
Image result for raijintek ereboss
That little guy, anyways the fan you see in front died so im looking for a 140mm replacement.
trouble is I have little knowledge about fans and ive been so out of touch with hardware for the past three years so I cant really remember much.
Anyways luckily Noctua has a 30ish% off sale right now so im looking for a replacement
Im unsure if I should be going for a cooler designed around max cfm or the ones that work best with radiators, I thought since the fin array is pretty dense it might still be a factor.
Also is Noctua still a good brand
Thanks in advance.
Listen if you care.
3 hours ago, Yatys 93 said:
Noctua is a good brand providing you don't mind the colours, static pressure is better for a cooler tower
It really depends on the fans and the heatsink, fan speed used, and so on. Pressure optimized fans won't necessarily be better.
Some heatsinks would work better with say a Corsair AF series over a SP series. Especially when the fin spacing is relatively wide and the stacks not too thick, there's not really as much restriction as you might think, and the fans won't be operating that far down the P-Q curve where a pressure optimized fan with worse performance in free air would pull ahead.
Eyeballing it, the Ereboss is not particularly dense, but it definitely doesn't have notably wide spacing either. The Ereboss comes with a slim 140 mm fan with mediocre static pressure, for what it's worth. But based on the design you don't want something with terrible static pressure, I'm sure.
I'm not sure which fans fit on the Ereboss, though. The mounting mechanism may or may not work with 25 mm thickness (standard) fans. I don't know offhand.
It should be fine with any fans with 120mm mounting holes that aren't so deep that you can't pull the rubber screws through--so 25mm should be fine.
@brownninja97
Static pressure is nothing without airflow and vice-versa. For a dense fin array, having a bit more static pressure can help.
Is your cooler still under warranty? If it is, you can just ask the manufacturer for a replacement fan.
If not, let us know what your budget is and what ram you're using.
@brownninja97
Stock samsung ram so no heatsinks, i can go up to £20 but I want to do it fast while the winter sales are still a thing. im fine with or without leds
Listen if you care.
Depending on how much you'd prefer to spend, some good options include:
Vortex: https://uk.pcpartpicker.com/product/BXDwrH/cougar-case-fan-cfv12hb
NB-eLoop: https://uk.pcpartpicker.com/product/NN8Zxr/noiseblocker-case-fan-nbeloopb122
NF-F12: https://uk.pcpartpicker.com/product/b2vRsY/noctua-case-fan-nff12pwm
