I recently just got a gtx770 by gigabyte, I was doing  a stress test today with MSI Kombustor and i noticed the molex connector on the molex to 8 pin was insanely hot
estimate about 100c is this a bad sign or just normal?
CPU: i7 6700 @ 4.25Ghz on 1.26 volts
RAM: HyperX 8GB @ 2666Mhz (doesnt like to be oc'd)
MOBO: MSI Z270 Gaming M3
GPU: Galax GTX 970 @ 1500Mhz  (with modified black EXOC bios)
Power Supply: Cougar CX700
SSD: Samsung 750 EVO 120GB
HDD: Segate Barrcuda 1TB
Case: Cougar Panzer Max
https://linustechtips.com/topic/87617-hot-molex-connector/
Molex connectors are not meant to carry that high current. I'd suggest to get a better power supply that has the connectors that you need.
https://linustechtips.com/topic/87617-hot-molex-connector/#findComment-1188148
Could be a bad connection between molex and adapter
You really shouldn't be using an adapter to connect a GPU to a molex. Molex are for fans and LEDs not power hungry GPUs.
"If you do not take your failures seriously you will continue to fail"
https://linustechtips.com/topic/87617-hot-molex-connector/#findComment-1188210
This is bad..........the heating may be due to the fact that the gfx card is sucking a lot of current or due to arcing between the connectors due to a improper connection!
Try reconnecting the adapters or else buy a new power supply sooner or later! Molex is not meant to power these power hungry cards but only for peripherals imo.
FX 6300 @ 4.2 Gigahurtz 1.325V ,  ASRock 970 Extreme 4 mobo  ,  Kingston Hyperx Blu 2X4GB @1600Mhz  , Asus GTX 960 DCU ii Black OC  , Hyper 212 Evo , Samsung 850 Evo 250 GB , WD 1 TB caviar Green , Xonar DG sound card , Seasonic M12ii Evo 620W PSU , Corsair 200R case ,4 random case fans.
https://linustechtips.com/topic/87617-hot-molex-connector/#findComment-1188527
I really dount its at 100C. How did you test it, by hand? If so you should have burnt hand by now. Its more likely something around 30-50C. 90-100C is what boiling water is.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/87617-hot-molex-connector/#findComment-1189080
There's no reason to be using a molex to 8-pin if you're running one graphics card...
If you're running two then you probably should upgrade to a beefier power supply anyway.
Intel Core i7-7700K | EVGA GeForce GTX 1080 FTW | ASUS ROG Strix Z270G Gaming | 32GB G-Skill TridentZ RGB DDR4-3200 | Corsair AX860i
Cooler Master MasterCase Pro 3 Samsung 950 Pro 256GB | Samsung 850 Evo 1TB | EKWB Custom Loop | Noctua NF-F12(x4)/NF-A14 LTT Special Edition
Dell S2716DGR | Corsair K95 RGB Platinum (Cherry MX Brown) | Logitech G502 Proteus Spectrum | FiiO E17 DAC/Amp | Beyerdynamic DT990 Pro
https://linustechtips.com/topic/87617-hot-molex-connector/#findComment-1189262
As far as I know the Gigabyte's GTX 770 comes with a double-molex to 6pin and a double-molex to 8-pin. Check that they are all well and securely connected.
On the other hand, I checked your profile for specs and the PSU you listed (Cooler power 700W) comes with a 6+2 PCIe connector, so why don't you connect that to 8pin on gfx card?
About the PSU, a 700W unit for $50 or something is a piece of crap that will destroy your PC. You should really invest in a good 80+ unit because a good 400-500W PSU will outperform a crappy 700W PSU any time 'n' day, especially under high loads.
MOBO: Gigabyte G1.Sniper M3 | CPU: Intel i7-3770K @ 4.5GHz | GPU: 2x Gigabyte GeForce GTX770 2GB WF3 OC Edition | RAM: Kingston HyperX Blue DDR3-1600 XMP 16GB (4x4GB) | SSD: Intel 530 Series 180GB SATAIII | HDD: WD Caviar Blue 1.0TB SATA III & WD AV-GP 3.0TB SATA IIPSU: Corsair AX 760 | Case: Chieftec DX-02B | CPU cooler:  Corsair H100i with 4 Noctua NF-F12's in Push-Pull | Fans: 3x Noctua NF-S12A Front and Rear-intake, 1x Noctua NF-A14 Bottom-intake, 1x CoolerMaster MegaFlow 200 Side Panel-intake, 1xNoctua NF-F12 Top-exhaust | OS: Windows 7 Ultimate 64-bit | Keyboard: Logitech G510 | Mouse: Gigabyte Aivia Krypton
https://linustechtips.com/topic/87617-hot-molex-connector/#findComment-1190007
Thanks for all the help guys :) I will be definetly investing in a new psu
https://linustechtips.com/topic/87617-hot-molex-connector/#findComment-1190771
