Looking for great headset for sensitive audio ques
PaPaNurgle
So i've been playing this game called "escape from tarkov" Where hearing is super important. I currently use an RGB void corsair wireless headset.
I'm curious on a moderate priced headset that makes those audio ques much easier to hear.
The headset needs to have a microphone as well.
Thanks in advanced guys!
3 minutes ago, kokakolia said:
I would recommend getting:
- Philips SHP 9500
- V-moda Boom Pro
Thanks i'm reading up on it right now.
- Philips SHP 9500
- V-moda Boom Pro
Yeah this sounds like exactly what you are looking for. Comfortable and a very detailed sounds with great soundstage. Just be aware that they are open back headphones! If you are playing somewhere quite and you don't mind sounds leak then these look like a fantastic option for you!
