Best Case for Air cooling
ReyazJunior
I'm not sure whether I will use a full-blown custom loop or a full-blown air cooling for keeping my PC chilly. For the water-cooled PC, I will use the Thermaltake Core P5 TG Snowflake edition. For the air-cooled system, I'm not quite sure. For air cooling, I will use a Noctua NH-D15S for the CPU, and an EVGA KingPin GTX 1080 Ti. That is final. Next, which case should I use for perfect air cooling? I don't quite like the CoolerMaster H500P, so that is out of question. I will also invest in a better motherboard (the Maximus X Hero instead of the Strix Z370-E). However, the money I am saving from the loop will compensate for the price bump in the motherboard and graphics card. I am using an i7-8700K.
the H500P would have been a poor choice for an airflow case, go for the silverstone RL06
Builds:
5 minutes ago, Froody129 said:
HAF X?
I am not a big fan of the looks.
It is not really on par for the looks.
6 minutes ago, ItsTheDuckAgain said:
Fractal Design Meshify C
anything more open and airflowy is close to an open air shoebox
I literally love the case. I am unable to find it anywhere in India. ?
Ok it's a great case
They have a tempered glass side version too! Suits me. But still, the Meshify C is a better option. Can't find it though, so I'll get the RL06.
Silverstone RL06 is THE BEST case for ariflow hands down.
well you asked FOR the best aircooling case, and thats the best one i know of. the H500P cant be considered an air cooling case, it just chokes everything
Builds:
I hope someone sues Cooler Master for false marketing as High Airflow is literally the opposite to that case's design xD:D
The Phanteks Enthoo Pro M is the only other modern case with I can think of right now that has a mesh front
Wow… the special edition has an acrylic window! Loving it. But now it's large size and rad support make me feel that i should do water cooling in it.
Phanteks cases aren't known for great airflow.
Anything from Fractal, NZXT, Corsair... Works.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
thats also one of the coolest cases i've ever seen
Antipixel  -  First build
https://pcpartpicker.com/b/wVmqqs
I mean the fractal define C and NZXT s340 are actually some of the warmer cases. and I was talking about mesh fronts - which generally tends to have better cooling. other phanteks cases are indeed bad like the enthoo evolv
