Hyper 212 EVO without fans?
So I decided to turn my old PC into a HTPC and im trying to keep it quiet as possible. The cpu is a pentium g3258 and im not going to overclock or play games just going to use it for websurfing. Is it possible to use it without putting a fan on my 212 evo heatsink?
https://linustechtips.com/topic/873667-hyper-212-evo-without-fans/
I don't think 1 fan will kill you, how loud could it possibly be
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
Not really, TBH for the size the 212 Evo isn't that effective a heatsink since you can get coolers designed for use with 92mm fans, which do a better job due to their newer designs.
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
Depends on airflow. I was able to run my G3258 semi-passive on one with it set to somewhere around 4.5GHz/1.3v (I think). With a bit of airflow I bet you could undervolt it a bit and run stock clocks passively pretty well.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
Just replace the the fan with a Be quiet fan and set it on the lowest RPM. Virtually no noise to be heard.
AX1600i owner. https://docs.google.com/spreadsheets/d/1_GMev0EwK37J3zZL98zIqF-OSBuHlFEHmrc_SPuYsjs/edit?usp=sharing My WIP Power Supply Guide.
18 minutes ago, Tellos said:
But hoenstly the 120MM fans are not that loud.
Due to them being only 1800RPM on the 212 Evo (I've got the 2200RPM model from a failed Seidon 120V, and the motor+airflow gets loud).
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
