4-pin CPU cord for Mobo?
Solved by W-L,
Just now, Johnmakuta said:Ok, it might be a tight fit but that'll work. I've had that with weird GPUs that have a 6+8 pin before.
Just fold up the extra +4 pin section so it gets out of the way, just note that PCI-E and EPS cables are not interchangeable to make that clear.
tippytipper ·
Posted in Storage Devices0 -
2
AlyShazli ·
Posted in New Builds and Planning3 -
4
Emmanuel Katto ·
Posted in Peripherals3 -
2
2
Rusty Proto ·
5
WildOne ·
Posted in New Builds and Planning2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
