is10bit worth worth it?
Mr.Sir
I'm deciding between 2 monitors 8bit or 10bit but the 10bit costs $200 more would it be worth it?
both are sVA panels with quantum dot 1440p
Just now, M.Yurizaki said:
Unless you're doing media creation work, no. And it's likely the 10-bit panel is 8-bit with FRC to simulate 10-bit color.
ok thanks
Yeah watch out for "fake" 10 bit :P
2 minutes ago, Mr.Sir said:
Yes, if you look around you can find places that tell the whole story of the specs and it's 8 bit + FRC
would you say it would look the same as the C27H711
That's a very different panel.  60 Hz instead of 144, just plain old 8 bit as far as I can tell, etc.  I haven't seen either in real life though so can't say how they look compared.
