Hello everyone.
I need help on deciding what case should i get next for my rig.
My rig is a prebuilt (well technically i choose the parts but it's built by the shop vendor) and i told the vendor to house the build in a minimalistic case. Sadly, those variants of cases have run out and i have to accept my rig in a case called Dazumba D-Vito 685
I have problems with this case...
1. Cheap build quality, like i put it on it's side to clean the power supply fan and the side panel bent
2. No filtration, dust gets in easily and as a result every 3 months i have to clean it
3. I'm just not a fan of it's aesthetics
4. You can't remove the front panel to clean it
I'm looking for a case that is:
1. Smaller than what i currently have that supports no larger than ATX (my motherboard is a Gigabyte H81M-DS2 3.0 https://www.gigabyte.com/Motherboard/GA-H81M-DS2-rev-30#ov). Also the place to put my PC measures at 300 mm width x 450 mm tall x 430 mm deep, for reference
2. Have plenty of filtration and removable front panel for cleaning
3. Can support ATX power supply (Corsair VS450) and able to fit a Radeon RX 470 reference
4. Have a window. I don't care about tempered glass but i need a window to check of dust
5. Preferably have more than 2 USB front (i have a USB Wi-Fi dongle i put on the front and i plug in my game pad when i play games)
6. Have a 5.5 inch drive bay for my DVD-RW (optional)
Price preferably under 100 USD
Thank you in advance
https://linustechtips.com/topic/866340-m-atx-cases-help/
Fractal Design Define C. Sleek, understated look. Acrylic and TG options, decent dust filtration, quiet etc.
There's also the Mini C, if you want a mATX case.
No DVD option, though. For that, you could get the Define R5 but it's over budget.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/866340-m-atx-cases-help/#findComment-10757165
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/866340-m-atx-cases-help/#findComment-10757166
https://linustechtips.com/topic/866340-m-atx-cases-help/#findComment-10757174
7 minutes ago, AP_97 said:
Sorry, but it's too long :(
Just filter on pcpartpicker and you'll get fewer results to sort through.
Desktop
CPUi5-6600K MotherboardGigabyte GA-Z170-HD3P CPU Cooler: Thermalright True Spirit 120M Black/white RAM: Corsair Vengeance LPX 16 GB DDR4 2400Mhz GPU: Gigabyte 1070 HDDs: 2 x Seagate Barracuda 2TB 7200 RPM  SSDSamsung EVO 850 500GB PSU: Coolermaster 550W 80+ Gold Case: NZXT S340 (White) with a white led strip ;)
Laptops
Dell 7577
CPUi7 7700HQ RAM: 16 GB DDR4 2400Mhz GPU: GTX1060 Max-q HDD: 1TB 5400 RPM  SSDNVMe 512GB SCREEN: 4k IPS 15.6"
Macbook pro 2018
CPUi7 RAM: 16 GB DDR4 2400Mhz GPU: Radeon Pro 555X 4GB Storage256GB SCREEN: 15"
https://linustechtips.com/topic/866340-m-atx-cases-help/#findComment-10757198
3 hours ago, AP_97 said:
Sorry, man but it's too big. Looking for a case that only supports M-ATX
Ahh I see, sorry I didn't see it if you mentioned it in your OP.
[edit] Also m-ATX isn't a case size it's a motherboard standard. You can get pretty big cases that are still m-ATX and smaller. If you say what size you need to have, if it needs to fit somewhere then we might be able to narrow it down for you.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/866340-m-atx-cases-help/#findComment-10757849
Focus G Mini?
https://www.superbiiz.com/detail.php?name=CA-FOMNBKW&c=CJ
15.08" x 8.07" x 18.27"
(383) x (205mm) x (464)
Corsair Carbide 88r
https://www.amazon.com/Corsair-CC-9011086-WW-Carbide-MicroATX-Mid-Tower/dp/B01550Y9GA
just a touch smaller all around
14.89" x 7.80" x 17.64"
https://linustechtips.com/topic/866340-m-atx-cases-help/#findComment-10757917
I'm aware that M-ATX are the motherboard sixe, it's just i need a case that only support M-ATX and under.
As for where i will be putting it. I have a space on my desk that has dimensions of ( L x W x T / 430mm x 300mm x 450mm )
So far the case that fit into it are the Fractal Design Mini C
https://linustechtips.com/topic/866340-m-atx-cases-help/#findComment-10760125
No, I'm saying there are cases that are m-ATX and lower that are still BIG, the dimensions are way more help in trying to figure out a case that will fit... the ATX standard you want is also relevant of course, but just saying the Size is the most defining factor in trying to help you find a case.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/866340-m-atx-cases-help/#findComment-10762011
