Max fps limit or no ?
Grigor
I set mine up because I didn't want the GPU to whine and heat up without any benefit. I also noticed that on my 60Hz panel 75 fps actually looks a lot worse.
I disabled it for CS:GO though. (I believe fps has an effect on something in the game.)
PC: CPU: Intel i7-4790 MB: Gigabyte B85N RAM: Adata 4GB + Kingston 8GB SSD: Samsung 850 EVO 500GB GPU: XFX GTR RX 480 8GB Case: Advantech IPC-510 PSU: Corsair RM1000i KB: Idobao x YMDK ID75 with Outemu Silent Grey Mouse: Logitech G305 Mousepad: LTT Deskpad Headphones: AKG K240 Sextett
Phone: Sony Xperia 5 II
Just now, DJ46 said:
I set mine up because I didn't want to GPU to whine and heat up without any benefit. I also noticed that on my 60Hz panel 75 fps actually looks a lot worse.
hm
More FPS => Less input lag
so its better with no limit..
Yes, but outside of a competitive games it doesent really make much of a difference.
The only game I know where it has a big (or any) effect is CS:GO.
I would recommend to set the limit to the highest refresh rate your monitor can display and make a custom profile for CS:GO. (In the AMD driver I set my global profile to limit my fps and turned the limiter off in the CS:GO profile.)
