XFX XTR650 Gold or go for newer Seasonic Focus?
iiNNeX
Hey guys,
Currently in a dilemma  about which PSU to pick for my build. I was looking around for 650W Gold rated fully modular PSUs and came across an ebay advert for a brand new XFX XTR650. After a bit of research it seems that it is no longer being made, but it was rated as a reasonably good unit. The price it is advertised for is £77.50.
On the other hand, I could go with a much newer unit for £10 more (Seasonic Focus Plus 650 Gold) which only just came out and seasonic is beast anyway. Is the XFX one a seasonic unit too?
Which would you go for?
Cheers
7800x3d - RTX 4090 FE - 64GB-6000C30 - 2x2TB 990 Pro - 4K 144HZ
PCPP: https://uk.pcpartpicker.com/list/mdRcqR
The Seasonic one because it's rated at tier 1 rather than tier 2 or the XFX (though both are very good)
Desktop benching:
Yeah I am aware of the Tiers, but I've had some really good Tier 3 PSUs in the past, so don't pay much attention to that. If it's a good unit then it's good. As for price, the XFX is very close to the Seasonic, so it might be worth going for the SS anyway. Cheers
The tertiary system refers to electrical performance and build quality. The Focus Plus simply performs better. For $10 more it's worth it, but not by much.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
Well, don't forget that the Focus doesn't seem as loud as the old G-Series.
So from that point of view it might be worth it either way...
See:
http://www.tweakpc.de/hardware/tests/netzteile/seasonic_focus_gold/s09.php
"Hell is full of good meanings, but Heaven is full of good works"
