Thermal take fan hub max rpm
A Silver
I finally got everything working in my pc but all the case fans are at max RPM and in the bios it says 0rpm for the case fans. When I unplug the sata power the fans stop and when I unplug the fan cable which goes from the motherboard to the hub nothing changes. Does this mean the fan hub is broken or what?
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: TeamSport Elite DDR5 2x16 4800mhz
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Gigabyte G1 Gaming GTX 1080
Case: Corsair Crystal 460X
PSU: Cosrair RM850X 80+ Gold
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
Are you referring to this unit here?
http://www.thermaltake.com/products-model.aspx?id=C_00002702
What fans do you have connected to the hub as it's a PWM based hub any 3 pin fan connected to it will only run at full RPM at 12V.
That is the unit. I am using hd120 fans with 4 pin pwm connectors
PC Specs:
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
They should work make sure your header you have the hub plugged into is a PWM based header and is configured within the BIOS to be PWM control.
