Notification sound
Go to solution Solved by colonel_mortis,
That issue sounds like it's probably something to do with your browser or speakers I'm afraid - it works fine for me and nobody else has reported it that I've seen.
On 10/11/2017 at 2:32 PM, L.Lawliet said:
What notification sounds? i am using chromium and never heard it
If you have notification sounds enabled in your notification settings, there should be a sound when you have an ltt tab open and receive a notification or PM.
There is this weird sound since the whole new facelift/upgrade of this forum where the notification sound sounds like the audio is being sent through water and then being heard through the water bubbles as they pop
or sensible explanation would be sounding like peaking audio
Am I the only one?
I was ignoring it for the past couple of months hoping it solves itself but it still remains strangely
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/857806-notification-sound/
Weird, I think it's the desktop notification that is enabled
ExSystems
https://linustechtips.com/topic/857806-notification-sound/#findComment-10682269
16 minutes ago, L.Lawliet said:
I did enabled/disabled it but never heard of the noise u mentioned.
Weirdly enough I just heard a notification come in which sounded fine, my chrome updated yesterday hmmm
I'll have to confirm when I open LTT again
ExSystems
https://linustechtips.com/topic/857806-notification-sound/#findComment-10682339
HTTP/2 203
https://linustechtips.com/topic/857806-notification-sound/#findComment-10686814
On mobile it also doesn't play any sound. It just pauses whatever music I'm playing :dry:
There is more that meets the eye
I see the soul that is inside
https://linustechtips.com/topic/857806-notification-sound/#findComment-10686968
I just gone ahead and disabled it, I feel like it stopped happening after I made this post. Issue is everytime I get home and open up ltt I forget that my speaker has this power saving mode which result in no sound as it turns back on after receiving audio thus I end up getting no sound on the forum
ExSystems
https://linustechtips.com/topic/857806-notification-sound/#findComment-10690959
For me at least, the noise is the sound of tapping on the bottom of a pringles can, which is fine with me.
pringles-potato-chips-can-3d-model-vt3he8Ixi_200.jpg.f27cc85b6a2bb2cb83fccdda17d85135.jpg
Latest version of google chrome.
https://linustechtips.com/topic/857806-notification-sound/#findComment-10692827
I turned it back on and will report back if it fixed itself this weekend
ExSystems
https://linustechtips.com/topic/857806-notification-sound/#findComment-10695702
Strangely it's perfectly fine now, I am glad the problem got fixed somehow. I am guessing it's probably the update from few days back
ExSystems
https://linustechtips.com/topic/857806-notification-sound/#findComment-10700235
