Medium/high-end speakers that fit with a multi-monitor setup?
I have a set of Micca MB42X and for desktop speakers they sound unreal for the size. I have these paired with a velodyne 12" powered subwoofer and small Lepai 2020 amp for the speakers. I am also using a FX-Audio Dac X-6 for my audio source so that helps a lot.
They are quite small speakers and maybe you could get away with them being laid down on their side behind your monitors or purchase some cheap wall mounting solutions for the speakers?
Speakers:
Amp:
Wall mounts:
DAC/AMP:
Total cost:
80.00 + 25.00 + 25.00 = 130.00$ USD before tax/shipping. for speakers, amp and wall mounts.
That leaves 50-60.00$ for a powered sub from craigslist which I'm sure there are a lot of. You really don't need a massive sub with these speakers they sound great by themselves so a small 8-10" used sub would fill in the lows perfectly.
Hope this was helpfull, good luck!
