How many and which particular cases or case series are there with native vertical mount for gpu?
I know Cooler Master has a mount for their MasterCase and MasterBox series and some case from Thermaltake has a vertical gpu mount. But what others are there?
I came up with this question when I was looking for a new case. The problem I have is that MasterBox and MasterCase only fit max gpu length 296mm with the 5.3" drive bay, which I need, and my Asus STRIX 1080 ti is 298mm long.
https://linustechtips.com/topic/856451-cases-with-vertical-gpu-mount/
Cooler master h500p
thermaltake view 27
thermaltake core p5
Mastercase pro 5 (with accessory)
CPU: Ryzen 1700@3.9ghz; GPU: EVGA 560 Ti 1gb; RAM: 16gb 2x8 Corsair Vengeance LPX DDR4-3000; PCPP: https://pcpartpicker.com/list/b3xzzM
2 hours ago, PeteTeradactyl said:
Deepcool Genome
A, they dont make it anymore, because:
B: It's an awful case. AIO leaks, over priced, shotty build quality and performance... There's a reason it has bad reviews and you cant find it anywhere
18 hours ago, ImNotThere said:
do some trimming? :P only need to shave 2 mm off of the drive bay or the shroud
Yeah, it's not that much and shouldn't make a difference but it would be nice if modding wasn't needed :D
Thanks for the answers people! Will be looking into these shortly
9 hours ago, PeteTeradactyl said:
Point B still valid
Ended up ordering MasterCase Pro 6 for 179€ from a local store. In Cooler Master's EU store it's 159€ but with shipping added it wouldn't be any cheaper.
Gonna be trimming the 5.25" drive bay a bit to make room for the GPU.
