What is the power limit for one 8 pin EPS connector?
Solved by i_build_nanosuits,
44 minutes ago, nelsonpong said:The question is what is the max amount of power the CPU is allowed to draw by specification if the motherboard has one 8 pin EPS connector? What about one 4 pin and two 8 pin EPS connectors?
Main Boards with an 8 pin EPS12V CPU power receptacle can supply 235 continuous watts
http://www.overclock.net/a/gpu-and-cpu-power-connections
The 4 pin supplies 155 watts, and the 8 pin supplies 235 continuous watts. For most of the newer processors, even during extreme overclocking, ether connector would work fine. If you want to, you can even connect both the 8 pin and 4 pin CPU connections, all it will do is farther increase the wattage that is available to the CPU (315 watts).
