I've seen how Linus has a motherboard wall in his office. I have decided that I want to do something similar. The only issue is that I don't want to ruin my wall by putting super glue all over it. Any ideas how I could somehow attach the motherboards to the wall without damaging it too much? Also Where would you guys recommend getting old/broken motherboards from seeing as I've only got about 3 spare motherboards?
Thanks
https://linustechtips.com/topic/852029-motherboard-wall/
Some kind of back board? Not sure what material would be cost effective though.  And you can look for recycling places, the location we take all of our can's and spare copper has a huge box of defunkt motherboards, I'm sure that would be your best bet.
edit: a backing could become intensive in labor and price. I think you'll need input but mostly trial and error.  Also can't believe they took it down >_<
Audio go Brrrrrr
https://linustechtips.com/topic/852029-motherboard-wall/#findComment-10617029
maybe a thick high quality piece of MDF
Main Rig | Personal Build | Windows 10 | R7 2700x 3.7~4.3ghz | ASUS ROG Strix B450-I | 16gb DDR4 3200mhz | GTX 1080 FE | Coolermaster Elite 130 | Corsair H60 | WD Blue SN500 500GB NVMe SSD + 1tb WD Green HDD + 1tb WD Blue HDD
Laptop | HP m6-w102dx | Windows 10 | i7-5500u 2.4~3.0ghz | 8gb DDR3L | GT 930m 2gb| 120gb Sandisk SSD
Phone | Pixel 3 | Verizon | 64gb
https://linustechtips.com/topic/852029-motherboard-wall/#findComment-10617215
You could install either some books or standoffs, you would only need two hooks or standoffs per board, realistically and that would be just two small screw sized holes in the wall.
In terms of getting boards, you could post and ad on Craiglist (or a local equivalent) or a more tech centered nearby/local forum and ask people if they have dead boards, if you can have them.
Thrift shops sometimes have some cheap old ones laying around for only a dollar or so per piece.
https://linustechtips.com/topic/852029-motherboard-wall/#findComment-10617700
You can probably get boards from an e-waste/recycling center if they are willing to sell them.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/852029-motherboard-wall/#findComment-10618446
If we're just talking drywall, screws (and washers depending on the screw you're using) would probably be the easiest, quickest, and most cost-effective solution for mounting. You would need 2-3 per motherboard rather than every single standoff hole. If and when you ever need to take them off, just a matter of filling the holes again, sand and re-paint.
As for motherboards, making some classified ads and such asking for defunct hardware/motherboards might get you some results. Going to a local e-recycler would be an easier option if they're willing to do it.
https://linustechtips.com/topic/852029-motherboard-wall/#findComment-10618492
