CX450M.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/850037-replacing-power-suppply/#findComment-10595485
Meh, group-regulated unit.
Get a Corsair CX450 instead: http://www.shoppingexpress.com.au/buy/corsair-cx450-450w-80-plus-bronze-power-supply/CP-9020120
DC-DC regulated with a LLC topology. Meaning that it's good.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/850037-replacing-power-suppply/#findComment-10595499
3 minutes ago, mopishcross17 said:
also btw i am in australia
CX450M anyway, that unit is horrible
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/850037-replacing-power-suppply/#findComment-10595512
Just now, mopishcross17 said:
whys that
They're not...
https://linustechtips.com/topic/850037-replacing-power-suppply/#findComment-10595534
Just now, bomberblyat said:
google corsair psu explode
Any unit can explode... just because there was an instance of a low-end Corsair unit frying itself, doesn't mean you can make a blanket statement that all of their units are bad. They're not.
https://linustechtips.com/topic/850037-replacing-power-suppply/#findComment-10595540
11 minutes ago, mariushm said:
reply with some links to stores you can buy from, so i can suggest something from what's available there
corsair is ok but often not great value for money
https://www.pccasegear.com/
let me know if the links dont work
https://linustechtips.com/topic/850037-replacing-power-suppply/#findComment-10595583
Corsair CX is basically your only good option right now in the budget category.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/850037-replacing-power-suppply/#findComment-10595603
You have a system that uses very little power, maybe around 200 watts when you're gaming.
The most power hungry thing in your pc would be the GTX 1060 and that uses up to maybe 125 watts when you're playing games.
The motherboard and cpu won't use more than 100w and the rest uses very little power.
So in theory, you don't even need 400w power supply but it would make sense to go for something a bit higher wattage in case you'd want to upgrade to some more expensive graphics card, or just to get something with longer warranty.
55$ : Silverstone Strider Essential 500w ( SST-ST50F-ES230 )  - Sirtec OEM (Sirfa , High Power), not modular  (400w on 12v, rest on 5v and 3.3v)  , 3 year warranty
65$ : Cooler Master MWE Bronze 450W  ( or mwave ) - HEC OEM, a bit more modern design than the SIlverstone, with dc-dc converters for lower voltages, so can do up to 420w on 12v where it matters, not special in any way otherwise, same 3 year warranty as the Silverstone
69$ : beQuiet system power 8 500w - fsp oem , silent fans, better efficiency (up to 87%), not much else to say
Maybe also FSP Hexa+ 500w for 64$ but personally didn't see reviews for this model yet so can't be 100% sure it's good
You said you're low on budget so can't see something better without going over 70$.
In general I recommend people to stay away from Thermaltake because they have loads of models of power supplies with very similar names, and one model may be good while another with very similar name would suck, or one version of the same model is made by an oem and the next version of the same model is by other oem with worse quality control or cheaper components used. So even reading reviews you could be easily tricked and you'd get something different than expected based on reviews.
Corsair CX is just not worth it at those prices (ex i saw CX500 v3 for 85$ , maybe for 75$ i would have linked to it above but even that it's pushing it a bit, it's not worth that much)
https://linustechtips.com/topic/850037-replacing-power-suppply/#findComment-10595632
1 hour ago, mopishcross17 said:
which website?
Yesterday, I told you what to get and provided links. (Purepower 10 400W, CX450 and CX450M)
On 22/10/2017 at 4:32 PM, Comic_Sans_MS said:
https://linustechtips.com/topic/850037-replacing-power-suppply/#findComment-10595764
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/850037-replacing-power-suppply/#findComment-10596370
7 hours ago, bomberblyat said:
they have bad parts on them and they live max 3years barely even that
You are high.
Google EVGA PSU explode.  Google Antec PSU explode.  Google Thermaltake PSU explode.
https://linustechtips.com/topic/850037-replacing-power-suppply/#findComment-10596512
Nope. Are you on drugs?
Any PSU can explode.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/850037-replacing-power-suppply/#findComment-10596609
*googles Seasonic PSU explode*
*sees one forum post about explosing seasonic psu*
seasonic must be shit, must have bad parts and live barely past 3 years!!!
https://linustechtips.com/topic/850037-replacing-power-suppply/#findComment-10596640
Only one forum post?  Your Google-fu is borked then.  On jonnyguru.com/forums alone I can find three in 2017 alone.
But to my point....  Yeah...  The number of negative end user reviews/comments is in direct proportion to the berth of product and the number of units sold.  You can Google just about anything to make the claim that "this or that" sucks.  It doesn't make it factual.
https://linustechtips.com/topic/850037-replacing-power-suppply/#findComment-10596892
Corsairs capacitors are bad and what bad parts on psu means? probably good psu yahooooo
https://linustechtips.com/topic/850037-replacing-power-suppply/#findComment-10597451
No, they are not. You're riding the 'ommggggg CX bad!!!!' train a little too hard. They've improved since then.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/850037-replacing-power-suppply/#findComment-10597761
