I need help. ASAP
Go to solution Solved by Danny_UK,
I wouldn't bother with changing windows editions.  Windows 10 seems to be windows 10, regardless of Home Pro or Enterprise.  I mean who uses telnet in todays day and age?  xD
I mean if you really really really want to change the windows version here are the steps: https://answers.microsoft.com/en-us/windows/forum/windows_10-windows_install/downgrade-from-windows-10-pro-to-home/345f5464-cb7a-44b3-8856-237cbec072c8?auth=1
But be warned, if you mess this up you will mess shit up completely.  You can only downgrade not upgrade using this method.  BUT AGAIN... I would not even bother doing it it makes no difference
Hope that helps
Hello dear people.
I have recently discoverd my Windows 10 beeing a paid Enterprise version and was simply wondering if I need to purchase a new product key if i want to downgrade to say windows 10 pro or home.
I am not sure if this is the place to go but I would really appreciate an answer since I'm not good with software.
Thanks.
https://linustechtips.com/topic/849074-i-need-help-asap/
You could like just keep using it as is? There hardly are any differences for common usage, assuming the key is still legit even if being used on the wrong place.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/849074-i-need-help-asap/#findComment-10585143
win 10 enterprise is superior to win 10 pro. it does everything pro does with a few more options, like cutting down on microsoft data collection
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/849074-i-need-help-asap/#findComment-10585153
Hope that helps
If my posts help out, let me know on the feedback buttons.
Parts: Ryzen 5 1600X / GTX 1080 / 16Gb Vengeance LPX / RGB Stuff....
Full Specs here: https://uk.pcpartpicker.com/list/LcdZVY - OR click my profile pic
https://linustechtips.com/topic/849074-i-need-help-asap/#findComment-10585158
Why bother? Dont enable enterprise functions and it should work just like the Home version.
Desktop benching:
https://linustechtips.com/topic/849074-i-need-help-asap/#findComment-10585161
True they have less ads and background bloating too, but thats about it
https://linustechtips.com/topic/849074-i-need-help-asap/#findComment-10585165
13 minutes ago, manikyath said:
the question is why you'd want to. i can see no reason at all to downgrade a windows key, there's nothing to gain in doing so, only to lose.
Hope that helps
well the reason is that I want to update to the Windows Fall creators uptade that microsoft just lanuched, but you are telling me there's no point?
(its a legit key aswell)
https://linustechtips.com/topic/849074-i-need-help-asap/#findComment-10585222
Just now, AlmightyJohn said:
Well the reason is that I want to update to the Windows Fall creators uptade that microsoft just lanuched, but you are telling me there's no point?
Pretty sure that the Enterprise edition will get that too but feel free to correct me.
Make sure to quote or tag people, so they get notified.
https://linustechtips.com/topic/849074-i-need-help-asap/#findComment-10585225
You are correct. The main difference is enterprise won't spring the update on you.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/849074-i-need-help-asap/#findComment-10585228
So you manually have to do it or something?
I just use Pro and it downloads stuff automatically which is nice but can be annoying.
https://linustechtips.com/topic/849074-i-need-help-asap/#findComment-10585230
depends on settings, enterprise has the option to delay updates for a decent length of time, not too sure if they have a delayed rollout as well, probably not a huge delay if they do
desktop
HTPC
https://linustechtips.com/topic/849074-i-need-help-asap/#findComment-10585253
1 minute ago, Cyracus said:
Depends on settings, enterprise has the option to delay updates for a decent length of time, not too sure if they have a delayed rollout as well, probably not a huge delay if they do
Ah i see thanks. :)
https://linustechtips.com/topic/849074-i-need-help-asap/#findComment-10585269
1 minute ago, AlmightyJohn said:
why would you want this?
delay updates? because microsoft breaks shit all the time, they don't even test in house for issues anymore
desktop
HTPC
https://linustechtips.com/topic/849074-i-need-help-asap/#findComment-10585271
3 minutes ago, AlmightyJohn said:
so you bassicly wait for a safe and working software update that you know will work
That should be a basic feature honestly.
Though they have the insider program so at least they do some real life testing.
https://linustechtips.com/topic/849074-i-need-help-asap/#findComment-10585303
yeah, microsoft has been breaking their OSs with updates since like ms dos (xD okay maybe not quite that far but at least since win95)
desktop
HTPC
https://linustechtips.com/topic/849074-i-need-help-asap/#findComment-10585308
1 hour ago, AlmightyJohn said:
Hello dear people.
Thanks.
I recommend keeping your Enterprise edition. You will have more control over your OS then normal, pretty much you have more admin controls, less telemetry to contend with (if your worried about that) and few other things Enterprise has tucked away.
Yup.
Incorrect, there is a vast difference between Home Edition and Enterprise Edition.  Telnet ... oooh.
Enterprise functions are automatically enabled with an Enterprise Edition ... and no.
Absolutely.
You have the ability to update your edition at your leisure as Enterprise Editions don't auto update the Features (only security updates) for good reason.
@GoodBytes can probably confirm this as I have yet read up to see if Enterprise will be getting this yet or not.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/849074-i-need-help-asap/#findComment-10585584
Yup.
Absolutely.
well this cleard up the most of it, Thanks
https://linustechtips.com/topic/849074-i-need-help-asap/#findComment-10585624
