Which one did LTT use in their last mineral oil PC build? Or was that the Puget Systems one..
https://linustechtips.com/topic/847497-oil-cooled-pc-case/#findComment-10567264
@Crunchy Dragon they used one of the last puget cases ever produced. Even with that case though they ended up with leaks, leading to the computer being scrapped.. Honestly an really nice hard line water cooled build would be the better option, maybe go crazy and get glass tubes made.
https://linustechtips.com/topic/847497-oil-cooled-pc-case/#findComment-10567272
2 minutes ago, IKnight said:
For a case? Just use a fishtank and dunk it in. xD
Luke could back this up, we all know how much he loves fishtank cases lol
https://linustechtips.com/topic/847497-oil-cooled-pc-case/#findComment-10567277
i already have a hardline system but ive been wanting a oil system for ages now ahah
https://linustechtips.com/topic/847497-oil-cooled-pc-case/#findComment-10567278
2 minutes ago, Desertpunk said:
That was the Puget Systems one sadly
The last one at this point unless someone wants to deal with patent laws. The only option as of current would be to design and create your own acrylic tank or get a general fish tank and fabricate the components you need to house the system.
https://linustechtips.com/topic/847497-oil-cooled-pc-case/#findComment-10567282
it's not really the "case" i need but a way to mount the motherboard, and everything else into it
Mount the mobo using the backplate off of an old case.
@Slickapprove? :P
https://linustechtips.com/topic/847497-oil-cooled-pc-case/#findComment-10567288
@Desertpunk think the first tank is your best idea, I'd grab a cheapy case from a scrapyard and tear it apart and use that to hold everything inside the case and you can hide any "feet support" under the fish rocks on the bottom. Also the cool thing of having a fish tank as a case and peoples reacttions to it. good part it you already have the water cooling parts so shouldn't be a problem.
Edit:
now you got me thinking about my PC into a Oil cooeld one.. thanks
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
https://linustechtips.com/topic/847497-oil-cooled-pc-case/#findComment-10567293
ah, I see, looking for that next computer high! Is it safe to assume that after oil cooled you will be going to phase change?!?
funny story i did that a couple years ago for shit and giggles ahah then my ex-girlfriend got angry and killed it (it still makes me sad sometimes)
https://linustechtips.com/topic/847497-oil-cooled-pc-case/#findComment-10567302
8 hours ago, Desertpunk said:
Hey everyone,
I've been wanting to build and oil PC for a while now but Puget Systems have stopped selling the kit that they used to sell does anyone know of a good quality alternative?
My suggestion is look for a fish tank.  Measure your Mother board height to make sure it will fit.  Then go and pick up a piece of acrylic and mount your board to that.  Then slide it into the tank.  You can make your own motherboard tray with the acrylic to mount and secure it so it won't tip.  I've been working on building a custom acrylic case for my wifes class room so she can make the other teachers jealous of her set up.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/847497-oil-cooled-pc-case/#findComment-10568859
Damn, this thread made me sad. I've been wanting to build tank system for a while, but now, when the family is starting to balance out and things aren't so crazy, I find Puget isn't doing this anymore, and then I learn they sent some cases to this place, and join up to find out they don't have them any more. :/
https://linustechtips.com/topic/847497-oil-cooled-pc-case/#findComment-10576040
Does anyone have some measurements for the pieces id need as its a bit of an odd request to ask for at a plastic fabricator
If you have an ATX case lying around, you could take measurements of that and chop off things as necessary.
https://linustechtips.com/topic/847497-oil-cooled-pc-case/#findComment-10576177
Here are some details you will need for a standard layout.
http://www.10stripe.com/featured/form/atx.php
http://www.protocase.com/resources/how-to-design-for-motherboards/
https://linustechtips.com/topic/847497-oil-cooled-pc-case/#findComment-10576205
15 hours ago, Number Muncher said:
Now that they have a 3D printer, maybe @Slick could do a custom oil build video and make the blueprints public.
If they ended up doing that, it'd make soo many people happy, if this thread is anything to go off. aha
https://linustechtips.com/topic/847497-oil-cooled-pc-case/#findComment-10578791
I did one of these years ago (years before LTT/Slick) since Puget is close.
It's cool for a minute but really not worth it for more than a week or two.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/847497-oil-cooled-pc-case/#findComment-10595806
