I'm looking to find a good mid or full tower case that has airflow and few other things. I'm willing to spend a decent amount on a case $80-$250. I like my case to be nice as its a centerpiece for me. Currently, I have an NZXT H440 Razer edition with every fan slot populated. Heres the rest of my build.
Build:
- Ryzen 1700x
- NZXT Kraken X62
- Gigabyte GA-Ax370-Gaming K7
- Evga Gtx 980 4GB
- Corsair 700w PSU
Heres the things I really want in a case:
- Good Airflow
- Tempered Glass
- PSU shroud
- RGB(if it has it if not at least viewable from the front)
- Good Aesthetics (I really like the CM H500p just not its crap build quality,)
Things if possible
- angle/front facing I/O
- 1-2 optical drives (not necessary)
If anyone has any good recommendations let me know thanks?
https://linustechtips.com/topic/845159-new-good-air-flow-case/
Corsair Crystal 570x? I really like the fractal Design Meshify C (which I will be getting next month) but is a bit short. Phanteks also make good cases like the eclipse p400
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
https://linustechtips.com/topic/845159-new-good-air-flow-case/#findComment-10543044
Meshify C
Enthoo Pro M TG
460x
https://linustechtips.com/topic/845159-new-good-air-flow-case/#findComment-10543557
Thanks every for the responses. Another thing I've been considering is getting a Phanteks Enthoo Evolv ATX tempered glass and modding the top and front panel for better air flow. Would It be worth the time? Cause right now im either thinking the Fractal Meshify or the CM C700p.
https://linustechtips.com/topic/845159-new-good-air-flow-case/#findComment-10546899
Not wort the time and cost IMO. Better to buy a case without a significant flaw like that.
https://linustechtips.com/topic/845159-new-good-air-flow-case/#findComment-10548120
