You can use PCPartPicker to figure it out, it's pretty good for compatibility.
Also, both sites have measurements listed. Probably takes less time than posting the question to figure it out. ;)
To answer you question, yes.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/844456-enthoo-evolv-shift-x/#findComment-10535262
11 minutes ago, Holmes2468 said:
Just says up to a dual slot
I dont think that card will fit because the Zotac Extreme is almost like a three wide GPU because of it's massive heat sink (like the asus strix and gigabyte aorus) I looked at all the builds done on PCPartPicker and they're all true dual slot cards (EVGA 1080ti SC, FTW3, Asus 1070 Strix, Zotac 1080 AMP, Vega 56, etc)
https://linustechtips.com/topic/844456-enthoo-evolv-shift-x/#findComment-10535786
  • 10 months later...
It's confirmed. I tried fitting the same card in the Evolv shift and it will not fit because it's too thick.
https://linustechtips.com/topic/844456-enthoo-evolv-shift-x/#findComment-11678282
