AC Battery Bank (Cont)
@Hackentosher, @mariushm Why are you recommending inverters. They are quite inefficient (especially for low loads,) meaning OP will not get alot of run time from the battery pack.
Given the cost of an AC inverter (especially a decent pure sine wave one,) I would recommend instead spending this on a laptop charger that is designed to run directly off the cigarette lighter sockets found in cars (If you buy the right one it will also have USB port(s).) This means the 12v from the batteries is still stepped up to 19v, but this is way more efficient than stepping the 12v up to 120VAC only to step the 120VAC back down to 19V.
IDK about inveter efficiency, but my knowledge of switch mode supplies and some common sense tells me that when you want to run something off a battery for a long period of time at all costs avoid unnecessarily transforming the voltage. As for the 85% efficiency, I suspect that will be an ideal that is only achieved at a very specific load.
The cigarette lighter charger also has the advantage that is will be a bit smaller/the same size as an inverter, and means that the original AC powered charger does not need to be carried.
As for batteries, i would recommend lead acid, as despite lithium having great energy density, battery management is quite complicated, and has fairly severe consequences if you get it wrong. If OP wants something that is small and light, using 18650 cells is a great choice, but you should be aware of the dangers associated with the cells. If you do decide to use them, I would recommend buying a good charger and battery management circuit. Lithium batteries require a very specific constant current and constant voltage charging profile, and can explode if charged over 4.2V. The management circuit is to ensure that power supply to the laptop is shut off before the battery goes too flat, as permanent damage is caused by draining lithium cells below 3.0V. I personally set the cut off at 3.8v for devices I have built to run off lithium batteries. However 3.6v should be fine for your purpose.
You should also be aware that lithium batteries loose capacity if they are stored fully charged for long periods of time. That is why all electronics that runs off lithium ships at around 60% charge, or 3.8v at the battery terminals. i would recommend buying a charger that has the option to only charge the battery to storage capacity.
I would also say that only 3 cells is a no-no. Whilst it would work, you would be much better off with 6 or 9 cells in 3 banks of 3 (or 2 banks of 3 if using 6 cells.) This is achieved by connecting the batteries so there are 3x 3 cell packs connected in series, and connecting these three packs in parallel.
This will provide much better results, as it means that each battery is only supplying 1/3 of the current. The reasoning for this is two fold:
Firstly, higher capacity (3000MAh) cells can only discharge at lower currents. You trade cell capacity directly for max discharge current. Banking up the cells in parallel means that each cell is providing less current, so a higher capacity cell can be used. This is more applicable to higher drain devices, so the effect will not be very significant with an idling laptop, but will be an important consideration if you want to run the laptop at full load.
Secondly, the capacity of batteries drops (usually scarily fast) at higher discharge currents. This means a 3000MAh rated cell can only supply 3000MAh at say 200mA load. If you place a 2A load on it, the capacity may drop to 1500MAh. This drop is battery specific, and the effect is lower with higher quality batteries. You need to look at the discharge curves in the battery data sheet to find out this information.
If you choose to use 3 cells, I would recommend a 2000MAh battery, with a higher max discharge current (it will experience less capacity drop under load).
If you choose to use 6 cells, go with a 2500MAh batttery. For 9, go with a 2500-3000MAh battery.
But make sure to look at the discharge curves for the cell, NOT just the stated capacity!!! Samsung cells are likely the best, but there are several different models and capacities.
If you decide to use lead acid, something around 4-9Ah would be a good choice. I have found sonnenschein batteries to be very good in the past.
