programming need help with python program
Solved by LtStaffel,
Here is a python 2.7 version of your script (because I'm using PyPy which is 2.7 style syntax)
Please mark this post as the answer so the thread is "solved"
from random import * def answer(): # You don't need elif, it either will be 1 or zero so only make one check and use else x = (randint(0, 1)) if x == 1: return "HEADS" else: return "TAILS" # You were returning the parameter given to the function, when the function didn't need a parameter # You were also printing the result instead of returning it playerChoice = str(raw_input("Heads or Tails: ")).upper() if playerChoice == 'HEADS' or 'TAILS': # You didn't indent properly print "You chose: " + playerChoice # You don't need to wait a split second # Also, the computer doesn't get a choice if the player chooses # Here we get the result using your function "answer" ans = answer() print "You chose ::: " + playerChoice print "The answer ::: " + ans if playerChoice == ans: print "You won!" else: print "You lost!" else: print "Invalid input!"
