Second build for me
Solved by comicsansms,
3 minutes ago, DriZyo said:I know but in corsair website say, Hx it better for gaming quality.
That's just marketing garbage, and it doesn't say that, it says "designed for gaming rigs", which just means their target audience is gamers, which stands for a lot of their product line.
The HX is the better PSUs out of the HX and TXM line, but that doesn't mean you should get that in particular. I would get the TX550M and a larger SSD or something. The HX will electrically preform better, but that has no impact in your gaming experience, and the TXM is already very good electrically.
Honestly, do what you want, it doesn't matter that much.
