SSD HELP!
Moeplazz
Hello, my ssd is appearing in the bios but isn't appearing in the folders. (I'm using windows 10 with my HDD as I was unable to install it with my ssd so I'm going to clone it when I get my ssd to work.
Why were you not able to install on the SSD...?
You should not be cloning windows.
Transfer windows from HDD to SSD  I meant
I connected the sata data and power cable and my pc can't identify it but the bios said "Kingston"
disk management?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
1 minute ago, SeanAngelo said:
disk management?
When you go in folders and click This pc > Devices and drives my SSD doesn't appear but my HDD does.
2 minutes ago, Sakkura said:
Try going into disk management, the drive may just need to be initialized.
I think I've found it, how do I initialize?
Don't transfer windows, do a clean install if you want to avoid issues.
https://www.howtogeek.com/224342/how-to-clean-install-windows-10/
1 minute ago, Moeplazz said:
Thanks!
Also remember to have your HDD unplugged while doing it, or the windows install can screw up.
