Running a Sata Drive over a Sd Card slot
Guest
I know back when Pata drives were popular you could get a CF to Pata converter because they spoke the same Command protocol is the same thing possible with SD and Sata? SD and Pata? or are they competly different.
SD runs over the USB bus, not the SATA bus, and is a completely different protocol.
"Not breaking it or making it worse is key."
"Bad choices make good stories."
They're completely different. SD uses its own protocol.
IS there to use some external circuity
make it run?
Take SD Slot          Turn into                        Sata
On Laptop                                               To plug a hard drive into
__________
 |                 |                          >           ______________
9 minutes ago, TheCherryKing said:
CFast runs over SATA.
My laptop has A SD card slot
I'm at a loss as to why anyone would want to do this when they could just do it with a USB adapter for a few bucks instead. o.O
