Upgrade Path Help
Solved by MiszS,
12 minutes ago, Capt_Monk said:Also FYI right now my GPU doesnt bottlenech at all. Playing most games on high settings it pushes 100 fps at 60-75% utilization. In minecraft which is my main game, it gets 2000+ fps with high settings
Well if you have a 100Hz monitor, then the monitor is the bottleneck, but in this case it doesn't even make sense to upgrade your PC, as it is already pretty good. The GPU you can upgrade to all depends on the resolution you play at, and your budget
