PC Set on Fire - Help?
Ardu
Title pretty much is what happened. Won't turn on now, I don't really know what to do. Kinda upsetting tbh. Help pls.
Current PC
CPUIntel Core i9 9900k
GPUGTX 1080 8GB FTW EVGA
MotherboardASUS PRIME Z370-A II
RAM: Corsair Vengeance LPX (2x8GB) DDR4 2400 Mhz
Storage 1: Samsung 850 EVO 250GB
Storage 2: Hyper X 240GB
PSU: Corsair RM750 80 Plus Gold 750W
Peripherals: Logitech G502 Hero//Corsair K70 MK 2 Cherry MX Red
Display: BenQ XL2430T 24-inch 144Hz
Just now, Himommies said:
Pretty sure it's just dead
It kinda turns on, but turns itself back off straight away. It's not an old PC. About a year and a half old.
Current PC
I mean like you set it on fire
PSU is probably dead
GPU and Mobo probaly too
My life
what was on fire?
did you open it to see what it looks like?
Any LEDs on when plugged in yet still off?
etc ... more info needed if you need help
If you need help with your forum account, please use the Forum Support form !
^ Set on fire could mean you put a lighter over your computer or your fucking power supply exploded.
Be needing more info
2 minutes ago, wkdpaul said:
what was on fire?
The part between the GPU and MOBO was the area on fire. When I opened and looked there was no visual damage of what I could tell. No LED's are on anywhere when turned on but still off.
Current PC
in that case, your motherboard is 99% dead.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
THis seems like a difficult case boys
@Chenny02 How did it catch on fire, or did it just Note 7 on you?
i like trains 🙂
Do you think that would be all or?
Current PC
The PCIe slot?
The motherboard is probably dead, the other components may be alright.
Do you know what caused the fire?
this
@Chenny02 if you're talking about the PCIE connector then the motherboard is probably dead and it's also possible the GPU sustained damages ...
Those are PCIE connectors, that's what caught fire?
you can hope
Desktop:
Laptop:
Note 7'd. Was just chilling and it shut off. Thought it was an outage but the rest of the power was still on. Turned PC back on. Flames.
Current PC
1 minute ago, Cinnabar Sonar said:
The PCIe slot?
Yeah that. I have no idea why the fire happened.
Current PC
Also, what were you doing when the fire happened?
Playing video games.
Current PC
It caught on fire AFTER you turned it back on?
this
Yeah, just the one the GPU was plugged into though.
Current PC
Correct.
Current PC
Photos (if available) might help...
My number one recommendation: DON'T TURN IT BACK ON until you've figured out what happened. :/
Was your gpu screwed onto the case?
Take out the GPU and see if there is a shortage.
i like trains 🙂
Um...
maybe try switching slots??
the motherboard is almost 100% dead, but you can hope that maybe only the PCI-e slot got ded
Desktop:
Laptop:
The PC looks fine, no changes at all. Yeah I won't be turning it on and off again.
Current PC
