PC Set on Fire - Help?
Ardu
2 minutes ago, Implosivetech said:
Was your gpu screwed onto the case?
Take out the GPU and see if there is a shortage.
It was. I already took it out and had a look but nothing seemed different. How do I do this? Sorry if that's a dumb question.
Current PC
CPUIntel Core i9 9900k
GPUGTX 1080 8GB FTW EVGA
MotherboardASUS PRIME Z370-A II
RAM: Corsair Vengeance LPX (2x8GB) DDR4 2400 Mhz
Storage 1: Samsung 850 EVO 250GB
Storage 2: Hyper X 240GB
PSU: Corsair RM750 80 Plus Gold 750W
Peripherals: Logitech G502 Hero//Corsair K70 MK 2 Cherry MX Red
Display: BenQ XL2430T 24-inch 144Hz
3 minutes ago, RadiatingLight said:
Um...
maybe try switching slots??
the motherboard is almost 100% dead, but you can hope that maybe only the PCI-e slot got ded
Sadly my GPU is too T H I C C to fit into the other slots.
Current PC
3 minutes ago, Cinnabar Sonar said:
The most likely culprit is the power supply.
The GPU/motherboard may have shorted as well.
Okay that's not good. Thanks for your help though.
Current PC
Sorry, how do you do what?
Maybe your mobo was faulty and blew a capacitor. See if any metal cylinders near the slot are inflated, or blown.
i like trains 🙂
4 minutes ago, VenomZ_ said:
what is your PSU?
Corsair 550 W RM550x Series 80 PLUS Gold Full Modular ATX Power Supply Unit - Black
Current PC
PSU *sounds* ok to me. What's your GPU & CPU? And do you have a bunch of other hardware drawing power?
Also here is an image of bad mobo capacitors (thanks Google):
How do I check if there was a shortage?
Nothing looks out of the ordinary.
Current PC
980Ti and a i7 6700, nothing other than my mic, keyboard and mouse. Yeah, they most certainly don't look like that.
Current PC
How long have you had the PSU?
i like trains 🙂
Visible evidence of a short will look like sparks were flying (sorta). Carbon scoring, or components that are loose or detached from the board. Invisible evidence of a short (which is a thing) is... well... invisible and requires other diagnostic tools.
About 20 months, give or take.
Current PC
If you can snap a picture of your mobo (front/back), GPU and, maybe, the PSU, someone's eagle eye on here might be able to spot something out of the ordinary that you might be missing.
(Maybe not back of Mobo if it's still seated in the case at the moment)
There were kinda sparks when I turned it on.
Current PC
Yeah this sounds like a good idea. Will have to wait until morning though as it's 02:22am here and there isn't really any good lighting to see.
Current PC
I'm going to guess that (somewhere) there is visible evidence of the fault. Without seeing for myself, my best guess is the PSU. Others will probably offer better advice.
If there was a way for you to test each component individually, (i.e. in another system & with a fire extinguisher) you could probably isolate the issue. But that's a risky approach and jeopardizes another PC.
Okay, thank you for you help.
Current PC
You might want to get one of these.
https://www.amazon.com/Thermaltake-Automated-Supply-Oversized-Supplies/dp/B005F778JO
It allows you to check the voltages of your power supply.
Bad solid state capacitors don't always show visible signs of damage.
Side note: If you've watched LTT for a while, you'll be familiar with the "Never Open The PSU" warning. Bear that in mind. Some capacitors can hold on to nasty voltage for longer than you would expect. Be careful about poking around.
Good point on the SS Caps. Might show carbon scoring around the area of issue... since there were sparks in this instance (as opposed to a silent component failure).
not nasty mf them shits can fkin kill you
Since there were sparks, there is probably physical damage somewhere.
The voltages are sometimes enough to kill an adult.  @Chenny02 Defiantly be careful.
6 minutes ago, Sierra Fox said:
well sounds like it's time to get a new everything
I'm holding out hope...
From the descriptions so far... there is a possibility that it's just the PSU and that the mobo survived. Mind you, that might not be a probability. :/
