I have just completed a new build with the following hardware:
Ryzen 7 1700x
MSI b350M Gaming Pro
G. Skill Flare X 2x8 3200Mhz
Corsair H100i
EVGA 650w BQ Gold+
BIOS IS CURRENT
Win 10 Pro 64Bit
I'm currently using an old ATI Radeon 4650 GPU while I save money for my 1070.
THE ISSUE
Upon completing the build, the PC worked perfectly. Bios was updated, MSI drivers (chipset, HD audio, etc.) installed, Windows was installed, played a few games of LoL.
The following day I powered down and removed the cables and MOBO to install standoffs on the case. Replaced all cables and powered on.
THE MACHINE WONT POST
I get a CPU fail light on the MOBO EZ Debug LED
https://linustechtips.com/topic/834555-ryzenb350-cpu-fail-led-no-post/
reseat the CPU.
if that doesn't work , RMA the CPU i guess.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
2 minutes ago, Biggerboot said:
How did you have the motherboard set up before installing the standoffs?  I would basically try whatever worked before, otherwise RMA the cpu.
Agreed: it's possible one of the mobo standoffs are not properly screwed or that you have an extra one. It's unlikely that there might be other kind of damage done but I wouldn't discard it either.
Current Rig
5 minutes ago, RadiatingLight said:
reseat the CPU.
Honestly when you try using a Ryzen 7 on one of the worse motherboards of the entire ryzen line up there is my bets are actually on a bad mobo... the socket could be malfunctioning.
Personal Desktop":
Luna, the temporary Desktop:
I had a similar issue while building custom cables for my rig (see signature). Plugged everything in and got memory issues. Reseated CPU and Waterblock + bacckplate and everything worked fine.
Also, the b350 boards are not the greatest, my brothers Asus B350 plus has random boot issues with a ryzen 3 above 3.9GHz. (When it works its stable at 4GHz)
Sync RGB fans with motherboard RGB header.
Main rig:
Ryzen 7 1700x (4.05GHz)
EVGA GTX 1070 FTW ACX 3.0
16GB G. Skill Flare X 3466MHz CL14
Crosshair VI Hero
EK Supremacy Evo
EVGA SuperNova 850 G2
Intel 540s 240GB, Intel 520 240GB + WD Black 500GB
Corsair Crystal Series 460x
Asus Strix Soar
Laptop:
Dell E6430s
i7-3520M + On board GPU
16GB 1600MHz DDR3.
