Need help overclocking a FX-9590
Go to solution Solved by luegnicl,
On 11.9.2017 at 4:23 PM, Morbidos said:
So apparently the i5 my friend has spare us an i5-760 is that usable?
no. in this case the fx 8350 is way better
Let me start of by apologizing if this is in the wrong section, looked for a OC section but didn't find it..
Ok so backstory, I was going to upgrade to Threadripper (AMD fanboy), but Norwegian prices and recent changes in my economy has led me to be stuck with the old FX.
So I want to push the most out of it, I have some knowlege about OC and IMO i should be able to do this but I for some reason just can't get this thing stable above stock, beginning to believe i have lost in the silicone lottery
Setup:
Motherboard: ASUS Crosshair v formula-z
CPU: as said FX-9590
RAM: 16 gb corsair venegance 1600mhz 9-9-9-24
cooling: custom loop watercooling
So what have i tried:
I tried to google, just so thats out there
I have tried the usual, leave the FSB to 200 and upping the multiplier to core speeds ranging from 4700 - 4900 and no matter what i do with Vcore it will not stabilize.. sometimes it will load windows and i get to log in before it either freeze or BSOD with different messages and sometimes just BSOD the second the lock screen loads.
Memory wise i have tried XMP profile. I have let the motherboard handle the timing numbers but sticking the speed to 1600, same result.  I have tried to lock down the timing with the speed on 1600, same result.
but if I clear CMOS and just put the memory speed at 1600 the motherboard boosts the CPU to 5 ghz when gaming...
I have checked all the power handeling settings I can find and set them to whatever the highest rating is..
So what do I want with this thread.
Basically I'm hoping some skilled user on here hopefully someone with FX-9590 experience can join me in my quest to push this sucker to it's max... hell, I'd go so far as to skype someone to get help if i knew who to call (don't think ghostbusters can help)
I ideally want to start with just Clear CMOS and go setting by setting cause I can't figure out where the problem is for the life of me...
I'm running BIOS 2201 which at the time of writing is the latest I can find.
https://linustechtips.com/topic/833526-need-help-overclocking-a-fx-9590/
it is just a factory overclocked 8370. in most cases you will not be able to overclock it any further.. if i was you i wouldnt try to overvolt it if you are willing to use it longer than 3 or so months from now.... it is a crazy chip, but nothing you can really overclock
Sell that potato CPU and buy something like an old i5 or whatever.
Anything is better than a 9590.
Start by buying a fire extinguisher... Really though a FX-9590 isn't worth any one's time when a Pentium g4560 performs the same.
Personal Desktop":
Luna, the temporary Desktop:
But can you do content creation on an i5? (I literally have no knowledge on intel so bare with me)
I render videos at least once a week so that would be a requirement...
You should ditch this processor, it was outdated already by the time it released, what kind of workload you actually need to do? If it is professional workload I am to assume you have a budget to spend on it being a necessity, a lot of people in here could help you make the most out of it if you provide sufficient information.
Personal Desktop":
Why not...
Rendering videos will just take a few more minutes.
For the first few years I was a youtuber I used a 2500k no problem.
If the video was long I would just render it overnight so I could play games during the day.
as I mentioned in my fist post, I was going to upgrade but a recent change in my economic situation have made that impossible now,
My work load is basically I have a mosquito sice youtube channel and do gaming and tech videos hence i need it to do both gaming and rendering. if I could i would ditch it but I need to wait and at the moment it looks to be a long wait before I can do any major investments...
3 minutes ago, Enderman said:
Why not...
aha ok!
I don't know where I have it from but thought i heard something about having to have a i7 to do rendering... but thanx for clearing that out... I might have a lead on a i5 that i could probs get for free... I'll check the exact model and get back to you...
3 minutes ago, Morbidos said:
Well overclock the FX-9590 will do you no good, it was shipped pretty much at its silicon maximum capacity, besides half the people who did try to force stuff like 5.2ghz~5.3ghz on it end up burning the motherboard vrm's or something and that pretty much means dead system extra expenses.
When you can upgrade you'll probably want a Ryzen 7 1700 based system, the 2 golden rules for Ryzen 7 1700 are AVOID MSi motherboards at all cost(prefer Asus or AsRock) and get 3000~3200mhz Samsung B-DIE memory ram.
Personal Desktop":
  • 3 weeks later...
