140mm or 120mm fan for rear
xsimplyjosh
I'm trying to run this air cooling set up of fans, preferably all ML140 and ML120 red LED variants is the choice.
2x exhaust on top [radiator & h100i v2] n stock corsair Fans.
3x intake on front 140mm
1x Stock Cooler master exhaust 140mm Fan on rear.
Im looking to change the 3x front to 140mm red LED look either SP140 or ML140.
my question is For going with a positive air pressure would you think 120mm or 140mm as rear is better in terms of personal preference? primarily asking because the price difference between ML120 and ML140 in my country is about 13$ [32 vs 45] so kinda steep
CPU: Intel Core i7-7700K | Motherboard: ASUS ROG STRIX Z270H | Graphics Card: ASUS ROG STRIX GTX 1080 Ti OCEdition | RAM: 16GB G.Skill Ripjaws V 3000MHz |Storage: 1 x Samsung 830 EVO Series 250GB | 1 x Samsung 960 PRO Series 512GB | 1 x Western Digital Blue 1TB | 1 x Western Digital Blue 4TB | PSU: Corsair RM750x 750W 80+ Gold Power Supply | Case: Cooler Master MasterCase 5 Pro |
Cooling: Corsair H100i v2 // 4x Corsair ML140 RED Fans // 2x Corsair ML120 RED Fans
Monitor: ASUS ROG Swift PG279Q 1440p 165Hz IPS G-Sync | Keyboard: Corsair K70 LUX Red LED, Cherry MX Brown Switches | Mouse: Corsair Glaive RGB | Speakers: Logitech Z623 THX Certified Speakers
I always stick the biggest thing I can into the slot for maximum performance...
Sexual innuendos aside, i dont think the price difference is worth it. a 120mm and 140mm wont perform that much different from eachother, so I'd go with the 120
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
Forgot to include; Given the case im working with is a cooler master mastercase 5, it is pretty big in terms of space already, non restricted airflow from front since i axed the Optical disk drive and the hard drive sits at the bottom part of the shroud.
im probably gonna be looking at it that 140mm doesn't have to spin as fast as the 120mm [rpm wise] to push the same amount of air
Might just end up getting the 120mm instead and save the 13$...  since it matches the 120mm rads at the top :) ... i agree with your comment too.
This is the main reason I love my three 200mm fans in my case. Great for open air! Not so much for RADs though lol
for the rads i was content with the h100i v2 low price and discount at that time... im not sure how much better with the h115i/h110i would be because due to the nature of the bracket on the top it would only fit 2x 140mm fans at max so it essentially would be operating in a pull config like it or not. so willing to make a few compromise in and out.
3x 200mm O_o im guessing your case is very boxy [the CM mastercase is kinda hexagonal-like despite the large width. [240mm]
Related image
36 minutes ago, TVwazhere said:
You got any pics of your build?
CPU - i7 8700K / Motherboard - ROG Strix Z370 E/ RAM - 32GB Cosair Vengeance DDR / GPU  - GTX 1080ti - EVGA FTW3 / PSU - Seasonic Snow Silent 750W / Cooling - Cryorig H7 Monitor - Acer X34 Predator / Sound - Corsair Void - Case - Meshify C
IMAG0393.thumb.jpg.03d3cde2c326135615261a1c02b9c70f.jpgIMAG0396.thumb.jpg.dd01c104aa1b1aec265e51db83838b3e.jpgIMAG0183.thumb.jpg.1e06f2da3ef14f0a737df01bc81e31e1.jpgSnapchat-1190278271.thumb.jpg.cc3d7f93816d67d51b6895400824c924.jpg
Offtopic: draaaaaven! <3
ontopic now i rememver that case from tt it looks so familiar now
I've dubbed my collection: Zoro The Poro and the Silver Scrub Squad
40 minutes ago, TVwazhere said:
Nice. Kind of miss my Level 10 sometimes.
Yeah I'll probably miss it once i upgrade well. 200mm fans have spoiled me (I might throw one in the 380t this system will eventually move into)
