Internet speed for lan party?
Solved by LAwLz,
Like other people have already said, you should be fine. Gaming typically uses very little bandwidth, so one or four players doesn't make much of a difference.
There is no need to worry about ports either. You will be bottlenecked by your Internet connection speed long before you get bottlenecked by your router/switch. That's of course assuming you won't start doing local file transfers between the computers. In that case you will be bottlenecked quite heavily.
- Prev
- 1
- 2
- Next
- Page 1 of 2
