Custom case airflow
Solved by Glennieboyyy007,
it looks a bit like the gpu isnt getting enough fresh air, if you look at the path that air will come through.
maybe try to add a vent (maybe with fan) underneath the gpu.
you could do some lines of it or so, but just that it can suck in its own fresh air.
but to the point, it wont hurt keeping it this way
themasteroftalking ·
1
5
uzivkovic97 ·
Posted in Linux, macOS and Everything Not-Windows4 -
11
OctaviousTheHonorable ·
Posted in General Discussion1 -
4
6
Real_Smoky ·
Posted in Laptops and Pre-Built Systems1 -
TannerMcCoolman ·
Posted in LTT Releases2
