HELP!!! Need a PC and Monitor for 1k AUD
AimShootFire
Hi, im looking into parts for a friend and i choose a keyboard and mouse for him, but i just need a pc and monitor. I was thinking a 1050 4gb with a i3 or maybe i5. (Also i would prefer Intel / Nvidia combo cause i know nothing about ryzen / amd.
You need to learn to post things in the right place.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
I don't understand why you would ask us for advice and then tell us you don't want ryzen. We're here to give you the best advice possible, and if that includes Ryzen then so be it.
HEADS UP, THIS ACCOUNT IS INACTIVE NOW
I'm keeping everything else the way it was for anyone who might check out my answers in future, but I won't be using LTT.
Don't forget to quote me when replying to me!
Please explain your question fully, so I can answer it fully.
PSU Tier List Cooler Tier List SSD Tier List  My Specs Below!
My PC:
CPU: Ryzen 5 1600 @ 3.2GHz
Cooler: Stock Wraith Spire
RAM: G.Skill Trident Z RGB 3000mHz 16GB DDR4 (2x8GB) RGB
Motherboard: Asus ROG Strix X370-F Gaming ATX
SSD: Crucial MX500 500GB 2.5"
HDD: Western Digital Blue 1TB 7200rpm
GPU: Asus ROG Strix OC GTX 1060 6GB
Case: Cooler Master H500P
PSU: Corsair RM650i 650W 80+ Gold Fully Modular
OS: Windows 10 Home 64-bit
Fans: 4x Cooler Master Masterfan Pro 120 Air Balance
Potato Laptop (Samsung Series 5 Ultrabook, 2013):
CPU: Intel Ivy Bridge i5 3337U @ 1.8GHz
RAM: 8GB DDR3 2133mhz SODIMM (1x4GB Samsung, 1x4GB Kingston)
SSD: Kingston 24GB SSD (originally for caching)
HDD: HGST 500GB 5400rpm
GPU: Intel HD 4000 Graphics
that's an extremely tight budget here in Aus, you will need to buy used most likely and look at older components, best you could do new would be a grand just for the pc itself
he didn't say he doesn't want a ryzen, just that he doesn't know anything about AMD's lineup, calm down
"I would pefer Intel/Nvidia combo" Sure, he isn't explicitly saying that he doesn't want Ryzen, but it just helps to be open. I'm completely calm.
My PC:
cool, if he wants a budget gaming rig in any case (including a monitor) he'll want to extend his budget to 1200 or so at least, prices are murder at the moment :/
edit: make some wishlists on various retailers sites such as PC case gear, newegg aus etc and tinker with builds until you find a mix that suits your preferences. if you're building for a friend it will be good experience for you rather than just outright asking someone else to do it.
Teach a man to fish
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  ($144.00 @ Shopping Express)
Motherboard: Gigabyte - GA-AB350M-D3H Micro ATX AM4 Motherboard  ($109.00 @ Shopping Express)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-3000 Memory  ($99.00 @ Umart)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($63.00 @ Shopping Express)
Video Card: GALAX - GeForce GTX 1050 Ti 4GB OC Video Card  ($215.00 @ Mwave Australia)
Case: Silverstone - PS08B (Black) MicroATX Mid Tower Case  ($45.00 @ Umart)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($75.00 @ Shopping Express)
Monitor: LG - 24MP58VQ-P 23.8" 1920x1080 60Hz Monitor  ($169.00 @ Shopping Express)
Total: $919.00
Generated by PCPartPicker 2017-08-24 11:16 AEST+1000
idk
AMD isn't that hard to understand just divide the number of cores it says it has by two and that's how many intel cores it has. the ghz rating is the same.
8 hours ago, hammer3339 said:
if his friend is interested in wringing all the perf out of a Ryzen he'll want to up to a b350 to OC as well as r3 being trash according to most youtube personalities, may want to go up to r5 1500 territory
that is a B350 motherboard, just not a good board.
what? maybe back on FX the first bit was true, but the second is not at all. learn what IPC is and come back to me.
idk
my mistake, i was getting mixed up with the A series boards, misread the AB350. still though, R3 is basically just an old i5 4460, maybe not even that much in terms of perf. Need the hyper-threading to get a bit more juice out of it
