Cooler recommendations for £50
Why go small when you have room for anything? U9B isn't worth the money unless you want silence and have size restrictions. U12S would be the one to pick, or U14S from Noctua coolers. But for the budget, these 3 are what I would recommend:
https://uk.pcpartpicker.com/product/jK8H99/cryorig-cpu-cooler-h5universal
https://uk.pcpartpicker.com/product/smbp99/be-quiet-cpu-cooler-bk015
https://uk.pcpartpicker.com/product/mjdqqs/phanteks-cpu-cooler-phtc12dx
E: Actually, U14S is just bit more https://www.amazon.co.uk/dp/B00C9FLSLY/?tag=pcp0f-21
There are some other killer choices if you aren't on tight budget:
https://uk.pcpartpicker.com/product/6CYXsY/thermalright-cpu-cooler-silverarrow
https://uk.pcpartpicker.com/product/dVwqqs/scythe-cpu-cooler-scfm1000
https://uk.pcpartpicker.com/product/7sL7YJ/cooler-master-cpu-cooler-mazt8pn418prr1
