4 minutes ago, rssr said:
asus prime a320 k motherboard
Get a b350 motherboard, trust me you want to overclock that 1200 its a little beast.
and is 1050ti better or an RX460 is??
1050Ti
https://linustechtips.com/topic/820018-ryzen-build-doubts/#findComment-10277665
1050Ti
dont forget about a nice small(or big which ever is cheaper and fits in ur case) and efficient cooler for ur overclock :)
ASUS Maximus VII Hero | i7 4790K OC 4.8GHZ | 4x8GB 2400MHz MSI GTX 1070 alphacool eiswolf gpx pro
Samsung 850 EVO 520GB + Corsair 525gb + 275gb SSD  2TB Seagate Barracuda | 8TB Seagate Archive
Cooler Master HAF-X 942 | EVGA Supernova 1000W 80+ Platinum | Custom watercooling loop (gpu+cpu)
360mm+180mm rad and 10 fans | Swiftech D5 mcp655-B
https://linustechtips.com/topic/820018-ryzen-build-doubts/#findComment-10277682
Just now, bughtoo said:
dont forget about a nice small and efficient cooler for ur overclock :)
Actually the wraith stock coolers aren't your typical trash, you can overclock your 1200/1300X on them to its max at comfortable temperatures
https://linustechtips.com/topic/820018-ryzen-build-doubts/#findComment-10277688
does 1200 come with a good wraith cooler? isnt it the smaller one that isnt as good? I would not doubt the wraith max to cool it, but the stealth? i have my doubts if it will be sufficient when OCed
https://linustechtips.com/topic/820018-ryzen-build-doubts/#findComment-10277692
1 minute ago, bughtoo said:
does 1200 come with a wraith cooler? isnt it the smaller one that isnt as good? I would not doubt the wraith max to cool it, but the stealth? i have my doubts it will be sufficient
Just now, RoryDash said:
I'd recommend the AIR 240 by Corsair and Noctua's AM4 cooler, these are 10/10 fantastic. Actually just did a Ryzen 1500X build with these parts last weekend for a Client with a GTX 980.
Nope with a  1200 you are completely fine with the little stealth.
https://www.techspot.com/review/1455-ryzen-3/page4.html
Quote
When overclocked, the 1200's idle temps were in the low 30s and stressing only the CPU saw temps max out at just 52 degrees while stressing the CPU+FPU+cache saw temps touch on 72 degrees, though 67 degrees was the norm here. I was still using the default fan curve and I would describe the Wraith Stealth as being quiet, which is probably the most shocking part.
https://linustechtips.com/topic/820018-ryzen-build-doubts/#findComment-10277709
Way lower thermal needs too though, a cooler that is sufficient for a 1700 (65W rating) sure as hell can run a 1200.
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/820018-ryzen-build-doubts/#findComment-10277728
You are correct about the stock cooler being fine, as I shared evidence for above. However a 1700 comes with a wraith spire and the 1200 comes with a wraith stealth. Difference being the stealth is all aluminium (no copper slug at the base to contact the IHS) and has 50% less heatsink, same fan though (ignoring the fact that the 1700 has an RGB fan, by same I meant performance).
https://linustechtips.com/topic/820018-ryzen-build-doubts/#findComment-10277741
Have the stock cooler on my 1700, OC it to 4.00ghz on a 1.375 voltage and the temps are still only at 60 even with high load
https://linustechtips.com/topic/820018-ryzen-build-doubts/#findComment-10277745
1.375V is high for the spire to deal with... I'd be surprised if those temps are genuine. Btw what are you quoting me for? All I said was the spire and stealth are different coolers.
https://linustechtips.com/topic/820018-ryzen-build-doubts/#findComment-10277749
No reason specifically you're correct 100% the stock cooler is actually the first of many from amd not to be garbage
https://linustechtips.com/topic/820018-ryzen-build-doubts/#findComment-10277752
Quite aware, pointing out that the heatsink that comes with the 1200 is 65w and technically capable of cooling a 1700.
https://linustechtips.com/topic/820018-ryzen-build-doubts/#findComment-10277758
4 minutes ago, Haeking said:
Intel I dont ever will take the stock cooler game seriously till amd just keeps taking customers with a great cpu and stock cooler combo
isn't that what the intel coolers are for?
Before they stopped using copper they where decent.....then they made it cheaper.....
Edited by fixitnow
Changed the picture
Have you tried turning it off and on again?
https://linustechtips.com/topic/820018-ryzen-build-doubts/#findComment-10277769
Just now, fixitnow said:
  Reveal hidden contents
Intel is just getting slapped in the face with a white glove by amd in so many ways, hopefully coffee lake isnt a bust
https://linustechtips.com/topic/820018-ryzen-build-doubts/#findComment-10277772
6 hours ago, tomle64 said:
Hey I use my intel cooler on my locked i5 it rig it works great
But you can't oc with it
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/820018-ryzen-build-doubts/#findComment-10279460
7 hours ago, rssr said:
thanks and will a 450w power supply be enough for this set up
Depends on quality.
No you can't. Comfortable temperatures wouldn't be right around TJ Maxx.
Since when is he going to overclock a locked i5? Also, you're wrong anyway. I've overclocked with the stock Intel cooler before, no problem.
OP- GTX 1050 is better than RX 460, so the 1050Ti is definitely better than the 460. Don't bother with an A320 chipset motherboard, they're cheap shit. Even the cheapest B350 board would be a better choice.
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
https://linustechtips.com/topic/820018-ryzen-build-doubts/#findComment-10279667
Ryzen tjmax is 95 degrees. Since when is 28 degrees below tjmax on the stock cooler too close? (note he was stressing cpu and fpu 100% so unrealistic for a gaming workload)
Edited by Ryan_Vickers
https://linustechtips.com/topic/820018-ryzen-build-doubts/#findComment-10279896
