So I am doing an "overhaul" of my PC, I'm recycling my i5 6600k, storage, cooling, and DDR4. I'm upgrading to the ROG Maximus IX Hero. I also managed to get my friend's pair of Evga ACX 3.0 1080s for free because he got 1080ti models. I am now wondering what case to get for my RGB themed build as I wanted the S340 Elite but I am afraid that with two 1080s it will get more than toasty inside and will reduce the performance of the cards. The InWin 303, the InWin 101, and the Phanteks 400 TGE are other candidates but as I have used the S340 in my previous build and I like it slightly more. Overall though I cannot make up my mind as to what to buy so I was wondering whether other people who have more experience with these cases and/or running SLI setups would be able to give me some insight into which one to pick.
https://linustechtips.com/topic/818956-case-for-my-setup/
I can seriously say do not go with the InWin 303. It's a great case but has absolutely terrible air flow and some really questionable design decisions when it comes to mounting drives.
I regret choosing it for my build, raised my custom loop temps by almost 10C.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/818956-case-for-my-setup/#findComment-10265219
Corsair Air 540
Phanteks Enthoo Evolve
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/818956-case-for-my-setup/#findComment-10265242
18 minutes ago, Admiraldeamlich said:
the corsair 400c is 119 cdn$ on amazon
Please don't get a 400C, man do I regret selling my S340 for it. the S340 was such a better case and with the S340 elite I could never advise the 400C
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
https://linustechtips.com/topic/818956-case-for-my-setup/#findComment-10265376
cougar panzer is my recommendation, big, has tempered glass, has a lot of airflow
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
https://linustechtips.com/topic/818956-case-for-my-setup/#findComment-10265398
@AK918 no e-atx motherboard support, some rads wont work on the top because they are too thick but if you cant fit your rad on the top you could always put it on the front!
https://linustechtips.com/topic/818956-case-for-my-setup/#findComment-10265466
10 hours ago, AK918 said:
I think I'll start a build log. Is there a particular sub forum for them?
https://linustechtips.com/main/forum/3-build-logs/
Also I know I'm late, but if you like the P400 but want more airflow, you might consider the Enthoo Pro M
https://www.newegg.ca/Product/Product.aspx?Item=N82E16811854042
Phanteks Enthoo Pro M Series PH-ES515PTG_BK Brushed Black Steel frame / ABS Front / Tempered Glass Window ATX Mid Tower Computer Case
https://linustechtips.com/topic/818956-case-for-my-setup/#findComment-10266850
