Help choose parts for a high end gaming pc
I'm going to build a gaming pc, my budget is 2000 euro, that's 2357.56 dollar. I have 2 pcs here, feel free to tweak.
CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor
Motherboard: Asus - STRIX Z270-E GAMING ATX LGA1151 Motherboard
Memory: Corsair - Vengeance LPX 16GB (4 x 4GB) DDR4-3000 Memory  (€155.89 @ Amazon Deutschland)
Storage: Seagate - FireCuda 2TB 3.5" 7200RPM Hybrid Internal Hard Drive
Video Card: Gigabyte - GeForce GTX 1080 Ti 11GB AORUS Video Card  (€757.00 @ Amazon Deutschland)
Case: Corsair - SPEC-ALPHA (Black/Yellow) ATX Mid Tower Case
Monitor: AOC - G2260VWQ6 21.5" 1920x1080 75Hz Monitor  (€137.83 @ Amazon Deutschland)
Other: Corsair CP-9020092-EU RMX Serie RM750X ATX/EPS Voll Modular 80 PLUS Gold 750W  Netzteil, EU  (€112.84 @ Amazon Deutschland)
Other: Noctua NH D15 (€89.90)
Total: €1253.46
Generated by PCPartPicker 2017-08-07 17:13 CEST+0200
and
CPU: AMD - Ryzen 7 1800X 3.6GHz 8-Core Processor  (€447.88 @ Amazon Deutschland)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  (€40.20 @ Amazon Deutschland)
Motherboard: Gigabyte - GA-AX370-Gaming K7 ATX AM4 Motherboard  (€223.31 @ Amazon Deutschland)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3000 Memory
Total: €1719.06
Generated by PCPartPicker 2017-08-07 17:40 CEST+0200
Ryzen. Get the 1700 though, to save some cash.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
why not 1700x?
Since my main pc sshd failed I had to use my mothers XD, I'm desperate for a new pc
Just now, TinyBolts said:
why not 1700x?
The 1700 overclocks just as high, but it cheaper. The main advantages of the X series; XFR and higher clocks, are negated when you manually OC.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
Dude! A 1080 Ti with a 75Hz 1080p display? o.O
Get a Ryzen 5 1600 so that you can save some money to get a 1440p screen ;)
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
get dual memory kit not quad with 4gigs
and your vga is overkill to your monitor
k, any reccommendations?
I just like seeing the slots full, gives me peace of mind
Ryzen doesn't play nice with more than 2 sticks though, so a 2x8GB kit is best for high RAM speeds (and @stealth80 proved RAM speed makes a massive difference).
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
your vga overkill to 1080p monitor
and if you want full slot get the 8gigs or 16gigs
so you dont waste so much slot to small size
everyone loves big ( ͡° ͜ʖ ͡°)
2 minutes ago, TinyBolts said:
what about the 7700k build?
i was talking about 7700k build
and 1800x seems ok but better choose 1700 for lower price 0.1ghz performance differences
you need to lower your gpu or up your monitor
  • Why not the 1600? I haven't seen any comparisons but I don't think the 8 core is really that beneficial for gaming.
  • No SSD? Sin.
  • Your motherboard is overkill.
  • Ryzen likes 2 sticks, not 4. 3200mhz+.
  • Why such a small monitor? The 1080 would suffice for that.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
  • No SSD? Sin.
good bios mobo seems good
not overkill if he used for OC or upgrade ability for "something"
1600 is best value and he wants high end, so 1700 is best value for high end
rest i agree with you
Except you can OC on any Ryzen board, and there's no upgrade that a higher end motherboard supports and others don't.
If he doesn't make use of the extra cores, it's a waste of money.
