Could someone help me make a build?
Solved by Septimus,
Here is a build that is between the two previously mentioned builds: https://pcpartpicker.com/list/CjdPpb
- $1000 base build, with the 4K monitor it's $1300, consider dropping to a 1080p monitor if you'd like.
Featured Topics
Shay04 ·
Posted in CPUs, Motherboards, and Memory1 -
1
hconverse02 ·
Posted in Audio11 -
Rogue57Chevy ·
Posted in Graphics Cards11 -
Ricodotsh ·
Posted in Power Supplies3 -
6
bloodknightoo ·
GreenGDK ·
Posted in Troubleshooting1 -
RLT_Byers ·
Posted in Peripherals1
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
