NZXT AER FAN AT 100% BUT 4pin to 3Pin on mobo
Solved by RadiatingLight,
3 minutes ago, Velinzor said:Won't it run off my CPU PWM
Specs say you have:
- 1 x 4-pin CPU fan connector
- 1 x 4-pin system fan connector
- 1 x 3-pin system fan connector
so just hook up the Y splitter to the system fan connector.
Featured Topics
Highguy ·
Posted in Troubleshooting0 -
3
johnny45 ·
Posted in Linux, macOS and Everything Not-Windows0 -
2
Dedayog ·
Posted in Peripherals3 -
2
